Click here to go to the first RED TEAM post in this thread.   Thread: Beta 3.2.8 Scarlet X crashing camera & forced shutdown.
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1 Beta 3.2.8 Scarlet X crashing camera & forced shutdown.
    Senior Member Robino_J's Avatar
    Mar 2012
    Is there a solution or workaround to the camera crash / forced shutdown when pressing record after 3.2.8 Beta "force_upgrade" update method.
    Sent my log to support and they said to do the "force_upgrade" update method which I tried many times and it is still crashing all the time when pressing record. Update goes fine (I guess...) since it displays the right firmware version in the system info.
    I know there is an official thread for beta 3.2.8 thread but my post always gets buried in between people talking about adding 24p 5K on Scarlet so I'm opening a dedicated thread as I'm not the only one experiencing the issue.
    Senior Member Jon Carr's Avatar
    Aug 2009
    NYC
    try rolling back and installing 3.0.7 first
    Dp Reel
    http://www.visualcinema.com/reels/
    Rentals in NYC
    http://www.visualcinema.com/rentals/cameras/
    EPIC-X #5359 GNX (soon to be Dragon)
    Canon & PL mount, Canon 16-35, 24-70, 70-200, Rokinon 24mm, 35mm, 85mm, & everything you need to shoot RED!
    It's REDcode or no code...
    Nov 2011
    I followed the recommended upgrade procedure to the Beta firmware, and I have not had a crash upon hitting record. I did, however have the camera remain stuck in record mode 3 times when media cards filled, requiring a forced shutdown. This also results in a fatal lockup when trying to play back the last clip recorded to the media when the camera is started again, resulting in another forced shutdown.
    I think Red has a lot of work to do on this piece of firmware.
    Mar 2012
    Quote Originally Posted by Jon Carr View Post
    Thanks Jon, I tried that but it still crashes the camera.
    Aug 2009
    NYC
    Quote Originally Posted by Robino_J View Post
    Sorry to say this but, if you can't record not in previous builds now. I would advise to sending the camera back to RED to get checked out.
    Dp Reel
    Rentals in NYC
    Mar 2012
    3.0.7 works great. I meant I rolled back to 3.0.7 first and re-installed the 3.2.8 and it still crashes. I thought that's what you were suggesting.
    did you try rolling back to 3.07, then a reset to factory settings, and then upgrade to 3.28?
    Mar 2012
    Quote Originally Posted by Robert Andriessen View Post
    Thanks for the suggestion I just tried this that was a good idea but it still crashes. Still get the "Error: 0x0000001e / Please save log and send to RED support" when trying to record.
  9.   Click here to go to the next RED TEAM post in this thread.
  #9
    We've received your log, thank you for submitting it. Everything was upgraded properly on your end using the force_upgrade. We're working on rolling out a fix for the particular problem you are seeing. Until we post another update, I recommend using 3.0.7 on your camera.
    The other posts are correct in saying that if you see any strange behavior after downgrading/upgrading, re-setting to factory defaults is the first step you should take to resolve any issues.
    -- Matthew Biederman
    Mar 2012
    Quote Originally Posted by TheBied View Post
    Thanks Matthew, I will wait for the fix.
