Thread: Anyone using the Nvidia Maximus (Quadro 4000 and Tesla 2075) with CS6 ?
Results 1 to 7 of 7
  1. #1 Anyone using the Nvidia Maximus (Quadro 4000 and Tesla 2075) with CS6 ?
    Senior Member Tom Daigon's Avatar
    Nov 2008
    Las Vegas NV
    Anyone using the Nvidia Maximus (Quadro 4000 and Tesla 2075) with CS6 ?I have heard from other sneak peek folks that it enhances playback in PrP and in AE raytrace mode things are supersonic (redraw and rendering).
    Tom Daigon
    Premiere Pro / After Effects
    HP Z820
    Dulce Pro DQg2 raid
    www.hdshotsandcuts.com
    http://www.youtube.com/watch?v=DxPrG3WUyz8
    Feb 2009
    San Juan, Puerto Rico
    Not here. But seriously tempted. Just can't find good info on it.
    ________________________________________
    Frank Cueto
    Reaktor Post & Transfer
    Baselight Color Correction and DI, DaVinci Film Transfers (S35,35,S16 & 16) & Tape to Tape
    Smoke Advanced & Smoke HD ON-Line Suites
    (3) GFX/VFX Suites
    (2) Final Cut Pro Suites with HD-SDI Monitoring and IO
    ProTools 5.1 HD Suite, with HD-SDI monitoring/IO,recording booth & FX-Music Libraries
    (2) On-Set workstations powered by RED Rocket™ with 16TB RAID 6 storage & Dual-ESata CFReaders
    Maximus is just a marketing name for multi-GPU combinations and nVidia promotes multiple Quadro cards or the Tesla cards as secondary GPUs. In reality, it also works with GeForce cards. The Tesla C2075 is essentially a Quadro 6000 without the video ports, so just there for additional processing.
    Anyway, yeah, the addition of a second GPU or Tesla card helps to speed up many of the display and FX operations in Premiere Pro. In AE it's only for the ray traced 3D render portion at the moment, which isn't much, but if you're making use of AE to place title or logo graphics that are rendered within, it really speeds up the process.
    Quadro 4000 is a great all-around video card. It's not the most powerful at anything, but for most video and 2D tasks it's more than fine and it holds up well for pushing around polygons and other 3D tasks. Combine it with a heavy-hitting CUDA card like the Tesla 2075 (or a GTX580) and you're flying. The GeForce GTX580 is faster and more powerful than the Tesla or Quadro 6000, but it comes with a few "gotchas". First off, it has half the amount of RAM, does not support ECC memory, it's FP operations are handled at lower precision for OpenGL, OpenCL and CUDA and it's generally not as well supported (profiled) by most of the professional CUDA applications out there. I haven't run my tests with the GTX580 in CS6 yet, so I can't comment as to how well it really performs there. I will say though that it totally smokes everything else, even a Quadro 6000, in DaVinci Resolve.
    - Jeff Kilgroe
    Senior Member Mike Tiffee's Avatar
    Nov 2011
    How do you set this up with GeForce cards? I have two GTX 580's and a Red Rocket. Does CS6 simply pick up the second 580? Do I need to put the cards in SLI? or standalone?
    Freelance Broadcast Technical Director
    Based in Charleston, SC
    Scarlet-X #1456
    Nov 2008
    Las Vegas NV
    Quadro 4000 is a great all-around video card. It's not the most powerful at anything, but for most video and 2D tasks it's more than fine and it holds up well for pushing around polygons and other 3D tasks. Combine it with a heavy-hitting CUDA card like the Tesla 2075 (or a GTX580) and you're flying. Resolve.
    Yes Jeff, my plan was to run the Quadro 4000 and the Tesla 2075 when I make the switch from Mac to PC. Now I just have to make sure they will fit in with the Kona 3 card and the Areca controller card. This is the unit from Puget that they will be components in.
    Tom Daigon
    HP Z820
    Dulce Pro DQg2 raid
    Feb 2009
    Any news on this front?
    I am building a 3d workstation, and kinda torn between a 690, quadro 5000 or 4000. Also trying to figure out if Maximus is worth it.
    Any news?
    Frank Cueto
    (3) GFX/VFX Suites
    Senior Member Simon Dunne's Avatar
    May 2007
    I went to test mine, but have had to order an upgraded power supply for my Z800!!! The standard one doesn't cut the mustard as all the cards in my machine eat a lot of power!!! I'll let you know how i get on when it's up and running.
