Thread: Truly Professional H264 .mov Encoder ?
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1 Truly Professional H264 .mov Encoder ?
    Mar 2008
    New York City
    Knowing that x264 doe good job (but i still quite can't figure out what is the best way to use it : (i tried hand break , but results was not so happy )
    i am wondering what encoder is considered top notch and professional to create H264 MOV , for instance the kind of quality that is available on iTunes/apple TV rental
    I use Matrox compress HD , and even if does a good job , sometime does some pretty big fuck up (bi pixelations etc...(there are some scene changes that i am NOT able to get properly encoded using that card ... and i have to say that using the latest compressor 4 , even if the speed is zoo slow , the quality is more precise than Compress HD matrox ...
    i think that segment re-encoding is the way to get an high quality H264 (so boosting data rate on specific scenes ) as well as multi passes (more the 2)
    i am wondering what kind of system is used to achieve the apple Tv H264 quality , that pack in 1.6 GB a 2h HD Movie with pretty stunning results
    as far as i know sony blu code does H264 and segment re-encoding , but i think only for H264 Blu ray compliant ...
    does anyone know how achieve truly professional H264 .mov ?
    As i said , many encoder does good job , but sometimes some scenes require re-encoding (suing different settings ) so i guess segment re-encoding is truly a must ...
    thanks a lot
    g
    Senior Member Alexander Mejia's Avatar
    Jun 2008
    Champaign, IL
    For Apple, the encoding black box that you send your media to is a closely guarded secret.
    If I had to take a guess, they would be using a professional encoder like MainConcept to make the masters, or their own special h.264 encoder that they rolled them selves. They do have hundreds of engineers that work there :)
    After that they multiplex the video stream, or just stuff it into a .mp4 container.
    Even apple doesn't deliver Quicktime files as deliverables to the consumer. You shouldn't either.
    Alexander Mejia, Video Editor, Colorist, and Compressionist Volition-Inc/THQ-Inc. @Alexander_Mejia
    Mar 2008
    New York City
    what is real world difference between delivering an H264 wrapped as .mov versus an H264 wrapped as .mp4 ?
    thanks
    g
    Jun 2008
    Champaign, IL
    Quote Originally Posted by Gabriele Turchi View Post
    a .mp4 is supported by consumers electronics, while .mov isn't
    The containers are different enough to warrant a compatbility issue, even if the stream inside is fully compatible.
    Also on PC's .mov files get decoded by Quicktime, which isn't a very good h.264 decoder for windows.
    Senior Member Brian Iannone's Avatar
    Sep 2011
    Los Angeles & France
    The best H.264 encoder I've found so far is the MainConcept H.264 encoder used in Sorenson Squeeze. Adobe Media Encoder's H.264 encoder was improved in CS6, however I haven't done any thorough tests yet.
    A 19-year-old student with a love for cinematography and a passion for geophysics.
    Personal: www.brianiannone.com, Portfolio: visuals.brianiannone.com, Business: www.ik3.co, Twitter: @brianiannone
    The List of Scarlet Names | The List of EPIC Names
    Nov 2011
    Brooklyn
    I work in broadcast cable, and everyone I know uses SORENSON SQUEEZE to make our .H264 deliverables. Like Brian said, the MainConcept encoder engine does appear to be best of the many Sorenson provides. Use at least 8000kbps, and a 2-Pass VBR.
    Hope this helps.
    ___________
    Nick Morrison
    Director, Producer, Writer (WGA-East)
    ASTRONAUT (Partner)
    www.astronautnyc.com
    www.nickmorrison.tv
    ASTRONAUT CAMERAS: Two Scarlets
    LENSES: Contax Multi-Cam Prime & Zoom Set (Leitaxed and RP Cine-Modded)
    POST: Avid Symphony Edit Suite, RRocket (x2)
    Mar 2008
    New York City
    well , 8 mbit/s is quite high nitrate for a good H264 delivery ... the HD Movies rented on iTunes use an average Bitrate of 4 - 4.5 ... and looks ""perfect "" ....
    i honestly tried main concept codec in squeeze (as well using the main concept encoder ) and i found the quality not good at all (unless using 10 Mbs bitrate)
    I am wondering if they use something like : bLu code , or cinema craft or cinevision .. and that they re-wrap as mp4 ...
    g
    Sep 2011
    By the way, for 1080p deliverables, I typical use 10 Mbps 2-pass VBR or multi-pass CBR (which does four to six passes) at High Profile, Level 4.1. If I'm encoding something that I know won't be used on mobile devices (only computers), then I'll use Level 5.1 at 10-20 Mbps.
    Also, iTunes 1080p media is encoded at a total audio and video data rate of 3.9-4.5 Mbps in H.264 High Profile, Level 4.0 (minimum).
    Mar 2008
    New York City
    hi brian ,
    but 10 Mbps constant data rate produce quite big file size , probably something around 80 MB/minute ...
    what i am noticing is that iTunes HD content are around 35MB/minute and looks almost perfect ...
    so my point here is that i quite can't find any encoder (i have not had the chance to test Blu code / cinevision / cinema craft HD ) that produce a great image having 35MB/minute file size ...
    otherwise even Matrox compress HD does a great Job having 90MB/minute file size encoded H264...
    g
    g
    Sep 2011
    hi brian ,
    g
    g
    Ah okay, I see. So you're looking to end up with a file in the 5 Mbps range? I had thought that you were just looking for H.264 encoder recommendations.
    What devices will you be delivering to? Also, you said that you had previously tried the MainConcept H.264 encoder in Sorenson Squeeze, but weren't impressed by the quality. What version of Squeeze were you using?
    If you were to encode a file to H.264 at High Profile, Level 4.0/4.1, it should look just as good as iTunes' 1080p content.
