Thread: How to calculate light loss in higher shutter speeds?
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Senior Member PatrickFaith's Avatar
    Nov 2011
    Northern California
    Quote Originally Posted by David Mullen ASC View Post
    The rough math just says that a jump from 1/50 to 1/100 means you've cut the exposure in half, i.e. by one stop, and 1/200 would be another stop loss from 1/100 (it's all halves or doubles), so from 1/50 to 1/125 would be about a stop and a third loss, if that's close enough for you. If you want to get more precise, you'd have to do more math... but in most cases, getting the correct exposure within a 1/3-stop is close enough.
    Does anyone ever change the "shutter speed" in a show or movie (shutter speed is constant for the entire show/movie), thus you only change the stop via ND filters or iris (i.e. t-stop) ?
    http://www.youtube.com/patrickfaithart & http://Pudl.tv
    "Litl" #250 "Pudl" #397 of "Ink" (Monochrome) #3752
    Senior Member William Albertini's Avatar
    Nov 2011
    New York, NY
    Quote Originally Posted by Nick Gardner View Post
    Seriously? Why do you own a professional camera if you don't know basic high school level photography? I don't mean to be a dick, but for fucks sake read a book. Forums are great for discussion, but if you don't have a grasp of the absolutely basic fundamentals, I highly recommend you read every book you can find on photography and cinematography. Start with the American Cinematographers Manual and google anything you don't understand. example -
    http://en.wikipedia.org/wiki/Shutter_speed
    Nick
    Calm down...
    Any one want to weigh in on shutter angle v shutter speed. I am beginning to find shutter angle to be a more intuitive approach to motion, even though I come from a still photography background...
    Feb 2007
    Austin,TX
    Quote Originally Posted by PatrickFaith View Post
    I think of it as a film camera and sometimes change the shutter angle for an effect or when I shoot hi-speed but I never change the speed/angle for exposure reasons. Ok, almost never, if I need another stop on a lock off e.g interior with no movement, then I may go to 1/24, but not for when there is too much light which I believe is your question. For stills photographers this is not usually an issue as they are not dealing with strobing in motion. I'd advise staying at 180 degrees or 1/48 but that's just me.
    http://shanefkelly.com
    Epix-X#607
    Wise men talk because they have something to say; fools, because they have to say something.
    Plato (427 BC - 347 BC)
    The biggest effect of changing Shutter Speed apart from exposure is motion blur rendering - so for shows/movies it'd often be for artistic reasons. Eg Saving Private Ryan beach landing scene, dream sequences, flashbacks.
    But I've seen it used for exposure control in things like tabletop food advert shots where motion is minimal, and the DOP dislikes using filters and wants Depth of Field to stay the same.
    Director/Digital Camera Operator/2nd AC/DIT/Data Manager
    London, UK.
    Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.
    Quote Originally Posted by William Albertini View Post
    Calm down...
    I find relative shutter angle more intuitive most of the time. But had to use absolute shutter speed in seconds when varispeed ramping on Red One so that exposure stayed the same throughout, and we had no way of iris ramping.
    London, UK.
    Feb 2007
    Austin,TX
    Calm down...
    I use both, having come from a movie background and using shutter degrees all of my life, I recently started to also think in shutter speeds. This came into play recently shooting hi-speed and needing to verify that the shutter speed was correct for the shot if I wanted it to appear with "normal motion blur" at 24fps. Basically, if 24fps is 1/48th, then 48fps is 1/96th, 120fps is 1/240th, just double the fps number and you will get the "correct" shutter speed. In degrees, this would be 24fps is 180 degrees, 48 is 90, 96 is 45 and so on. I didn't have the epic reading degrees and couldn't find the menu item to change it in the heat of the moment and so had to think in shutter speeds. It's elementary math but very necessary.
    Epix-X#607
    Senior Member Nick Gardner's Avatar
    Oct 2007
    Baltimore
    Perhaps the language barrier made it sound like I was calling you an asshole. I was merely shocked that you lack an understanding of the basic fundamentals of photography. Rather than ask here piece by piece, I was suggesting that if you read a book, you would get a better grasp on how the basics all work together. If you don't have an understanding of shutter speed and exposure, nothing else is going to make sense.
    Nick
    Nov 2011
    Brooklyn
    Quote Originally Posted by Shane Kelly View Post
    Shane is there a way to MANUALLY dial in the shutter speed and shutter angle independently of each other? Or are they always tied together like this?
    EX: lets say I'm shooting at 24fps at 1/48th (STANDARD), but I want a 90degree shutter angle instead of 180. Is that possible, or am I being crazy?
    Beause the shuttle ANGLE is how much of the 360degree shutter is OPEN or CLOSED. And the SPEED is how many times said shutter rotates per sec right? Surely they can be seperated? Or am I missing something clutch and looking like a total idiot?
    Thanks in advance.
    ___________
    Nick Morrison
    Director, Producer, Writer (WGA-East)
    ASTRONAUT (Partner)
    www.astronautnyc.com
    www.nickmorrison.tv
    ASTRONAUT CAMERAS: Two Scarlets
    LENSES: Contax Multi-Cam Prime & Zoom Set (Leitaxed and RP Cine-Modded)
    POST: Avid Symphony Edit Suite, RRocket (x2)
    Quote Originally Posted by Nick Morrison View Post
    Thanks in advance.
    "Shutter Speed" and "Shutter Angle" are different ways of describing the same thing - ie how long the camera is sampling light WITHIN each frame interval. So those specific terms are tied together.
    With an electronic shutter, Shutter Speed can theoretically be any time value from zero (albeit pretty useless as that's just black!) to a maximum length of the frame interval, and Shutter Angle can be any angle from zero to 360degrees.
    However, FRAME Speed and Shutter Angle are indeed independent, so you can be at 24fps and in theory have any Shutter Speed from zero to 1/24th sec, or any Shutter Angle from zero to 360degrees.
    London, UK.
    Feb 2007
    Austin,TX
    Thanks in advance.
    Nick, what Eric said. They are essentially the same thing, just different ways of expressing it. You are correct on the shutter angle but speed has traditionally referred to the amount of time that a stills camera opened its shutter- a different mechanism to the movie camera's rotating shutter. What it comes down to is the amount of time that light is reaching the film/sensor and the characteristic motion blur that results from this value.
    As per your example, if you are shooting 24fps and want a 90 degrees shutter angle, then you dial in 90 degrees or switch to 1/96th sec, they are the same thing. No you cannot separate them.
    Epix-X#607
