Thread: SCRATCH drive space requirement for R3D editing
Results 1 to 10 of 10
  1. #1 SCRATCH drive space requirement for R3D editing
    Senior Member Will Keir's Avatar
    Sep 2009
    California
    Hey guys, about to configure my RAID 0 with two partitions, 1) for apps etc... 2) scratch drive for FCP.
    How big should my scratch drive be?
    I have 1.2GB total available space, so I could go 600gb/600gb or 400gb/800gb, what is working out there, what is too much, what is too little for the scratch and apps. Currently I think 500GB is about right for apps on the main partition. Thanks for any guidance/advice.
    Will Keir
    Creative Director ~ Jumping Rock Pictures
    Epic DRAGON #2482 / R1 #3033
    "Why I choose film?
    The friendships, the adventure, the art."
    Sep 2009
    California
    anyone?
    Will Keir
    "Why I choose film?
    Sep 2009
    California
    man, I was hoping to avoid going to Creative COW.
    Will Keir
    "Why I choose film?
    Member Frederick Giles's Avatar
    Jul 2009
    Fredericton, NB
    Scratch size depends alot on how big your R3D projects are going to be, for a feature you want to have 4TB and you should have a completely separate drive for system/apps.
    Sep 2009
    California
    wow 4tb!
    Will Keir
    "Why I choose film?
    Junior Member Grant H's Avatar
    Nov 2011
    Chicago, IL
    Quote Originally Posted by Will Keir View Post
    wow 4tb!
    It's a couple of 2tb drives. Barely an expense in the grand scheme of things.
    It is also a terrible idea to partition your scratch disk. It needs to be separate to everything else otherwise you're just increasing latency/read times. Rendering it somewhat useless.
    Senior Member Tom.Wong's Avatar
    Jul 2009
    New York/New Jersey
    have a single disk for just your boot drive and apps. whether it be a ssd or normal spinning disc.
    raid should be it's own entity like grant said. when building a raid you have to worry about block sizes too. for big video, you tend to want a larger block size, but for apps and so on you need smaller. plus a raid 0 has a higher risk of failure. one drive does, it all goes. so you want to only use it for stuff you have backed up already.
    always use the same brand and model of drives in the raid. don't mix and match you'll suffer massive performance hits. a raid will always default to the slowest drive in the array and force the other drives to match its speed. so you want everything with identical performance.
    Local 600 IATSE Digital Imaging Technician
    Phantom Certified Technician
    Da Vinci Resolve Colorist
    Scratch Lab Operator
    https://vimeo.com/41679679
    Senior Member Jim Geduldick's Avatar
    Jan 2007
    NY & LA
    As Tom mentioned buying drives in bulk if you can from the same manufacturer is something I do .
    One gotcha with this to keep an eye on if you frequent some of the tech blogs and performance sites that report on bad drive lots you might also want to keep an eye on the raid if you have serial numbers that fall within those bad lots.
    You can get very inexpensive raid chassis these days with Thunderbolt/Mini-SAS/eSATA that will be much faster then Firewire
    Director of Photography / Editor / VFX Artist
    Phantom High Speed Operator / Tech
    TWITTER-@filmbot
    Senior Member Jarek Zabczynski's Avatar
    Poughkeepsie, NY
    SSD for apps/boot, RAID5 for scratch, plus backup.
    Shoot for the Impossible...Then do it.
    Jarek Zabczynski
    Director / Editor / Cinematographer
    Epic X - #5515 | www.jarek.com | WE'LL BE ALRIGHT (Music Video) | INCREDIBLE (Scarlet Music Video)
    Nov 2011
    Chicago, IL
    Quote Originally Posted by Jarek Zabczynski View Post
    Curious as to why you think RAID5 for Scratch? Nothing truly important exists on the Scratch other than temp and render previews. If anything performance is better suited there and an incremental/nightly backup taken from it.
