It's a culture thing. When you've grown up with 35mm, 16mm and endless telecine sessions that ended up in SD you have a different sense to sharpness than someone who is used to video or DSLRs. None is better or worse, it's different. The equation Red=soft is as old as Red is on she market; and, IMHO, determined by taste. Nonetheless, cameras are different, so is their sharpness. Arri, for instance has a tad more sharpness in their debayer than RED, the Si2k is even softer. Adding electronic sharpness in the finishing process is done oftentimes, regardless which camera was used.
All this, however, has nothing to do with the OP's problems. I would listen to David Mullen's suggestion and get a second camera and additional sharp glass.
As a personal side-note: Red's compression has problems with high detailed scenes such as parks and trees. When I shoot at 3K and a compression lower than 1:5 I get clunky artifacts in the shadows. The problem is easy to solve: don't lower compression down to 1:8 or even lower. But you've all done that. Listen to David Mullen.
Hans
hmm, the OPs results are not far from mine. I never posted this here but I was quite disappointed when I saw my first footage from the Scarlet. Spoke to a buddy next to me (with EPIC and Scarlet) and he told me I´ll get used to it, it´s quite in line. Not that you cannot get it sharp in post, but at least quite noisy when sharpened, you can even see some noise in that test chart shot from David Mullen in this thread (I give the scarlet enough light, expose around 500ISO) ,so what Marie wrote seems reasonable to me. On the other hand, I´d love to get sharper results straight out of the camera - @Michael, please keep us informed about your findings.
Thank you, Ulf
Hello Hans,
Thank you. Sent you an email.
Cheers, Ulf
There's still something very wrong in your debayer or capture in the 3:1 though:
That's not optical. Did you rescale the image or apply sharpening or something? Nothing should create that artifact though.
Which image did you pull this off of? I looked at the "wide_3to1.jpg" and didnt see it. Hrmmm. Id like to find the original image so I can send it to Red. Sent the camera in for RMA today. They say 3-5 days to evaluate it and then they will service it or send me another one. May not have a camera again until June 4th! crazy. 2.5 weeks lost to a bad camera and Im supposed to be shooting days later. I dont want this one back and this is just one more reason why.
