Click here to go to the first RED TEAM post in this thread.   Thread: Beta Camera Build 3.2.13
Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 51 to 60 of 88
  1. #51
    Senior Member Raphael Varandas's Avatar
    Jan 2008
    Sao Paulo - Brazil
    Where can I send log ? Red support did not send me any feedback since yesterday. I am having major Sdi problems with 2 Scarlett's and 1 epic M... Help me pls.
    DCINE
    Cinematografia Digital
    www.dcine.tv
    www.vimeo.com/dcine
    www.facebook.com/Dcine.Digital.Cinema
    2x RED 1 MX
    2x EPIC M
    1x EPIC X
    2x SCARLET
    5i set coming
    Leica set coming
    atendimento@dcine.tv
    raphael@dcine.tv
    SAO PAULO / BRASIL / 55.11.55498419
    Good morning, when I use my bomb viewfinder now, I can't see the white balance and ISO settings change with the image. When I use the touch screen everything is fine.
    Any idea?
    Thank you,
    Best Tim
    Hi, thanks for your response. I rolled back to earlier firmware, as this version is not working, if you use your viewfinder together with your redmote. Have I posted something wrong?
    Best, Tim
    Senior Member Joel Arvidsson's Avatar
    Nov 2008
    Sweden
    Is there a time frame when we can expect next build? I really want the new "key mapping" but I rather wait than run the beta. The question is how long the "wait" going to be.
    Scarlet #00549 Elmer
    i cant get phantom power working. i have a properly made xlr to balanced mini cable and several phantom powered mikes and all of them give me lots of noise and a clicking sound. the same cables worked on the last release build with no clicking sound or noise, using different microphones that had their own power though..
    anyone else having issues?
    I am trying to use the force preset files in Scarlet_build_3_v3.2.13.
    I upgraded, reformatted the SSD on my mac using Fat32 and placed the monitor_presets_3_2_X folder on the card. I then inserted the card and powered up the camera. I still get no output on the monitor. Any ideas what I might be doing wrong? Many Thanks, Adam
    Adam Levins
    Scarlet-x Package
    Leica R 24mm 35mm 50mm 60mm Macro 90mm
    Grip and HMI Lighting kit
    www.levinspictures.com
  7.   Click here to go to the next RED TEAM post in this thread.
  #57
    Quote Originally Posted by Adam Levins View Post
    - Create a folder called "force_preset" on the top level of your SSD
    - Place the desired preset in the folder
    - With your camera OFF, insert the SSD into the camera
    - Start the camera, The preset will be applied on startup
    -- Matthew Biederman
    Quote Originally Posted by TheBied View Post
    Thanks! worked perfect. When I reformat the card I have replace the force preset folder on the redmag or can I set the camera to boot to HDMI by default? Regards, Adam
    Adam Levins
    Scarlet-x Package
  9.   Click here to go to the next RED TEAM post in this thread.
  #59
    The camera will continue to have HDMI enabled at boot now until you:
    - reset factory defaults
    - perform an upgrade
    - disable it in the monitor control dialog
    You should only need the force_preset file again in one of those cases.
    I've been running the 3.2.13 beta all weekend now on my Epic X, and it has worked fine except for one thing: sometimes the camera boots to the monitor half white/black and stays there. Have to do a hard reboot and try again. A few times it's take up to 15 restarts before I got the camera going and no half white/black view. I am very happy with it otherwise, but got to downgrade to be able to work properly with the camera.
    If it is possible to send you some kind of log file, where can I find instructions on how to do it? Thanks.
    Gear: Epic X, Quad battery adapter, Red Volt XLs, 5" RED Pro monitor, Redmote.
