I LOVE 3.2.13 however my Epic-X does not keep timecode (clock or date) when the battery is changed. It always did before. My rep, Nar, said to re-install the firmware but that didn't fix it. Suggestions? I assume there is a small internal battery that keeps time that could be dead? I only just got the camera at the end of Feb. Nar also said I could send it in, but it's working too often to be without it for week or more. Any thoughts would be greatly appreciated. Thank you!
I was seeing too many bits of wackiness with 3.2.13 - lcd white / cards not recognized when insterted / battery percentage not displayed. I missed a shot at an event because of the media thing, so I rolled back to 3.07 today. Will wait for a new update.
Going to BEG for power management in the next build ( I know it's in the plan ) and also wonder if we can get our redvolt chargers to start charging after the batteries are cooled. I understand if they can't start charging warm, but they should start once cool enough. I know there is no firmware updating the charger...
I'm shooting 4K QuadHD on a Scarlet at 23.97.
I can output to my Samsung monitor using HDMI at 1080p 60 Hz and the monitor displays 1080p60.
If I change the Scarlet to the new output of 1080p 24 hz, the monitor says it's an unrecognized format.
If I change to 1080p 30 Hz, the monitors says it is displaying 1080p60.
If I connect a Canon HV20, the monitor says it's displaying 1080i60 - so it seems pretty good about showing which format it's seeing.
If I output the 1080p 24 Hz to a Black Magic Intensity card, it displays nothing.
Same for 25 Hz and 30 Hz - it doesn't detect it as a valid signal (the Black Magic cannot accept 1080p60).
The Black Magic card will accept 1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30.
The Black Magic will also accept 1080i50, 1080i59.94, 1080i60 - so it works perfectly with the Canon HV20.
At the moment, I don't have a way to record 1080p using the Black Magic and the Scarlet.
So, with the two pieces of equipment I've tried to use in my studio, the new 24 Hz 1080p24 doesn't seem to be working.
I did connect the Scarlet at 1080p 24 Hz to a very large Sharp HDTV. It would sometimes display it, but at times had artifacts and problems where I had to switch to another input and back again. Although the Sharp will show an informational message of 1080p24 when I play BluRays, it didn't show what format it thinks it's receiving when I had the Scarlet set to 1080p 24 Hz for some reason.
BTW - as I intend to use this for capturing video and audio, as a backup in case of problems (which might come in handy if the audio gets out of sync, as recently reported), it would be great if instead of just 24 Hz, if it could also output 23.97 to match the recording format (as it seems to do for SDI)
Thanks a lot for adding this feature!!! I'm really looking forward to using it.
I would like to report a bug. If you roll out a mag, camera freezes and keeps recording.
Also getting in and out of keys locked on the REDmote is now a hassle, seems to be a bug on the REDmote's firmware.
When recording in my studio, my workflow is to have the camera connected to an HDMI splitter.
One output goes to a large monitor for checking focus and framing - and the other goes to a Black Magic Intensity card, currently connected to a MacPro with FCP7 (but soon I'll move everything to AE/Premiere on Win7 where I'm doing all my R3D file editing) where it records ProRes 422 HQ.
With a 'normal' camera, recording the hdmi feed bypasses all the mpeg compression and gives you true 1920 x 1080 from a DV camera.
I can record the session in 1080p with sound and immediately review the take on a large monitor with studio sound monitors.
Most of my takes are very short, but they need to be perfect. If I don't like a performance, I can immediately show the talent what they are doing wrong, and get them to correct it.
It's great to be able to look at a high quality version of what was just shot immediately, without having to deal with pulling R3Ds off the flash. I'll know exactly what a debayered output will look like (and sound like), in advance.
My hope is that when the 1080p24 is working, that I'll be able to do this with the Scarlet.
The Black Magic card in the Mac Pro won't record 1080p60, so I need to get the Scarlet to output at 1080p24 or hopefully 1080p23.97. The same goes for the Matrox MXO2, it won't work at 1080p60.
Unless there's a problem with the R3D files, I doubt the 1080p recording will be used for anything but review, but ... it never hurts to have a backup for video as well as sound (as some are reporting audio synch issues lately).
I'm toying with the idea of doing this in the field also, using a Win7 laptop (and external monitor) and a Black Magic USB3 Intensity - as I've gotten used to having a large monitor when recording.
The laptop would serve double duty for pulling R3D files off the flash cards to back them up and recycle them.
