Thread: Little 400 fps test
Results 1 to 5 of 5
  1. #1 Little 400 fps test
    http://www.youtube.com/watch?v=ZBFAXH6XuVk
    Live fall! Watch in hd full screen
    Senior Member Justin Marx's Avatar
    Jul 2011
    Hollywood, FL
    So little I missed it ;-)
    EPIC-M 1261 - officially named "Take 2"
    hey Justin,
    Yes, it's only 2 seconds but i liked it so posted:)
    More soon!
    Senior Member Mike Lary's Avatar
    Mar 2011
    Seoul, South Korea
    Ariel,
    To eliminate strobing when shooting at high frame rates you need to use larger light sources (2K or higher if you're in the states). If you don't have access to bigger lights, the sun will do the trick.
    Good luck with your testing, and thanks for not shooting water. ;)
    Mike Lary
    Director of Technology, DIGITAL FACTORY, Seoul
    Digital Revolution Since 2009
    Color Correction/Digital Workflow/Red Camera Rental
    www.DigitalFactory.kr
    Quote Originally Posted by Mike Lary View Post
    Ariel,
    Thank you Mike. The flicker is probably from the overhead fluorescents that were working and not from the 1k. This was really a 5 minutes test :)
