Thread: Avid MC 6.0.1: AMA Producer Task::Execute AMA Plug-in Unable to Provide Sample
Results 1 to 5 of 5
  1. #1 Avid MC 6.0.1: AMA Producer Task::Execute AMA Plug-in Unable to Provide Sample
    Junior Member
    Jun 2008
    I'm working with Avid MC 6.0.1 on a MacPro (2x2.93 Ghz Quad-Core Intel Xeon w/ 18GB RAM on OS X v10.7.4).
    We shooting R3D Epic in 5K. The media goes onto an internal 16TB Raid system (4x 4TB).
    We've been linking the RED footage via AMA. The editorial process was fine for a while, but now an error has been coming up more and more:
    I haven't been able to completely understand the error. Everything plays fine and than it halts during playback. Once playback stopped, I can't even play the master clip any more. I matched back to it and tried stepping through it frame by frame, but the picture drops out at the same frame where it stopped playing in the timeline. I was able to bring it back online by re-importing via an ALE and was playable again. So I'm tempted to rule out a corrupt source file...
    Is it just a speed thing (drive or CPU speed)?
    Any idea would help.
    Thanks,
    Carsten
    Member Roger Viloria's Avatar
    May 2011
    Studio City, CA USA
    Hey Carsten, I am having the same problem :(
    Did you find a solution to it? Any help is very appreciated!
    Roger
    Aug 2007
    Boston
    Make sure you're not using the QuickTime AMA plug-in to the proxies. Select RED R3D from the menu in the dialog box when linking.
    Michael
    Ernst Lubitsch
    I've never seen this error, but would like to hear the solution if anyone finds one. Is your RED AMA plug-in up to date / correct?
    Scarlet-X Owner
    #415 "Miss P"
    Red Rocket Owner
    Also, make sure you're using the "Link to AMA Volume" and not the "Link to AMA File" command.
    Scarlet-X Owner
    #415 "Miss P"
    Red Rocket Owner
Tags for this Thread
View Tag Cloud
