Thread: SOS - Problem with 1 Take on SSD CARD
Results 1 to 4 of 4
  1. #1 SOS - Problem with 1 Take on SSD CARD
    Senior Member Vigen Vartanov's Avatar
    May 2007
    Tbilisi , Georgia
    Good day .
    Today i got footage from production for dailies , and found that 1 take on AXX card is damage .
    Looks like it very long take , 4 R3Ds are in folder . RedCine - X did not recognize it , also Scratch is stocks when i am truing to load this shoot .
    Checking with RedUndead now , but because original media is few tapes reformatted , i just copy this files back to SSD and now waiting for RedUndead .
    Problem is that it is very important take . Any ideas or solutions ?
    Having reformatted numerous times over the media is bad news for a REDundead recovery. Have you tried loading clips individually? I've had corrupt clips that will not load in the most modern REDCINE-X but will in old RED Alert - R1MX originated. It may not be ideal but if it get you something, its better than nothing.
    I've also had a clip that had a corrupt FRAME or even a few corrupt frames in sequence. By determining where they are, you can set in/out points around them . RCX remains stable until it hits that bad data. Then just export a new R3D trimmed excluding the bad portion of the clip.
    EXAMPLE:
    You have a 20 frame clip
    Frame 10 is corrupt
    Set in at frame 0
    Set out at frame 9
    Export that range
    Clear in/out
    Set in at frame 11
    Set out at frame 20
    Export that range
    You'll have 2 clips instead of one but it will play back and export - even though its missing a frame in the middle.
    Hopefully you're able to at least open the clips... Best luck
    Michael "Strawberry" Romano
    ICG Local 600 DIT | West Coast USA | Honolulu, Hawaii
    Mobile: 239-218-4452
    http://www.strawberrycolor.com/
    http://www.sightandsoundhawaii.com/
    May 2007
    Tbilisi , Georgia
    RedAlert did not helps .
    Senior Member Bérenger Brillante's Avatar
    Dec 2007
    Paris, France, Western Europe
    Try in premiere. I didn't have corrupted files on my epic yet, but with my MX it has saved some footage several times.
    You will have some corrupted frame though.
    Bérenger Brillante / Diffraction
    Crew with equipment, for hire in Europe
    www.dif-fraction.com
