Thread: Arri FF4 and RED
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Digital FX Greg M's Avatar
    Quote Originally Posted by Petros Nousias View Post
    What I AM trying to figure out is whether the ff4 will fit WITHOUT the bridgeplate...
    How are you attaching the Rods?
    Are you getting the base production pack?
    btw- both the FF4 and FF5 fit all three standards (19mm, 15mm and LW15mm), so I dont understand what your dealer is talking about. The problem w/ the FF5 is that it does not properly fit Cine lenses.
    digitalfx.tv
    The RGBlog- Ramblings about Cameras, VFX, etc.
    Twitter
    Red One #83
    Epic-M #98 and #240
    Epic-X #83 and #116
    Banned
    Jan 2007
    Quote Originally Posted by Finner View Post
    Thats a good idea if you plan to use the arri bridge plate with an arri camera, not the best idea if you want to use it on a red camera. The arri bridge plate is different from the red ET plate and the arri one will not work on a red camera.
    Hey Finner,
    I'm just asking...are you sure the Arri bridge plate won't work with the RED? My deal is I have an Arri FF-2, Arri MB-18, (both 15mm based) Arri bridge plate and dove tail I was hoping to use with my RED package. I would hate to have to spend another $600 for the 15mm ET (arri) bridge plate.
    I wonder if I could go to a shop and get another hole drilled, tap/dyed with my current bridge plate and have it be able to work on my film and RED cameras.
    Jan 2007
    I am getting the base production pack, so the rod-lens distance is less than with the bridgeplate combination, hence my question. It doesnt have to do with the rod diameter. Also that was not the dealers guess but arri's(he contacted them about the ff4 and they suggested I purchase the ff5)
    Hollywood, CA
    Every Arri rep I've spoken to has pointed me towards the FF4, not the FF5.
    The FF5 is designed with a longer gear arm made for HD lenses with a smaller diameter construction.
    This retailer wouldn't happen to be Filmtools would it? They seem to be stuck on the idea that the RED camera is meant for the FF5, not true.
    http://www.filmtools.com/red-one-camera-outfitters.html
    Someone needs to speak with them on their reasoning....?!?
    There have been complaints of the FF5 not working properly with a RED/Cine lens setup.
    Cinematographer
    www.AlexanderNikishin.com
    Epic-X #149 "KING"
    Rental inquiries: www.AlexanderNikishin.com/gear.html
    Senior Member Mike Prevette's Avatar
    New York, NY
    Petros the Rod distances will be the same as the 19mm arri ET base. it's a standard set of dimensions.
    _mike
    "One for a meal, One for the reel, or One to learn something"
    I dont understand- the rod-lens distance is standard, it cant be different or it simply wont work.
    Regardless, the FF5 is not appropiate for Cine lenses. I bought it per Arri recomendation when it first came out and had to return it after a dozen calls to Arri, when they finally admitted that it is really for Video Lenses.
    There is an entire thread I started last year on this topic with complete details on why it doesnt work.
    Bottom line is if you are using Super Speeds and Ultra Primes, etc... DO NOT BUY THE FF5.
    The FF4 works perfectly.
    digitalfx.tv
    Twitter
    Red One #83
    Epic-M #98 and #240
    Epic-X #83 and #116
    Jan 2007
    Thanks, that was a clear answer. I was not talking about the rod to rod distance, bat the rod-lens one. If the red bottom plate positions the rods higher than the bridgeplate(which seems like it does if you take a close look at the picture) then the follow focus will be positioned higher, and could be in the way of some bigger lenses. Enough said though, I will be getting the ff4 since Ive used it a million times and find it excellent in every aspect.
    Nov 2007
    I believe the RED rods are properly positioned. This is how they were able to mount an MB20 and have it line up correctly with their lens. There are lots of pictures of this setup floating around.
    Mitch Gross
    Abel Cine Tech
    the height is exactly the same either way....otherwise it wouldnt work.
    see image below of attached MB20II and FF4.
    I am using the RED- Arri 19mm Base, but also have the RED basic production pack and the Red bottom plate is exactly the same positioning.
    Note how short the gear arm is, on the FF5 the gear arm reaches to the top of the lens, which creates many issues. It wont allow positioning the arm under the lens (which I do all the time), it creates problems with the matte box and prevents the clip on from fitting properly. Not to mention is geared differently.
    digitalfx.tv
    Twitter
    Red One #83
    Epic-M #98 and #240
    Epic-X #83 and #116
    Jan 2007
    Thanks for all the answers, it was quite stupid of me not to think of the issues the mattebox would have if the rods were set higher...
