Thread: Lomo 100mm Round Front anamorphic sharpness test
Results 1 to 3 of 3
  1. #1 Lomo 100mm Round Front anamorphic sharpness test
    Senior Member Adnan Siddiqui's Avatar
    Aug 2011
    NYC
    Lomo Anamorphic PL/BNCR (35, 50, 75mm) Round Fronts
    Lomo Anamorphic PL(35, 50, 75, 100, 150mm) Round Fronts
    Lomo Anamorphic PL (35, 50, 80mm) Square Fronts
    Canon (11-16mm Tokina, 35mm L F/1.4, 55mm F/1.2, 70-200mm L II)
    The Clutch
    Digital BarTech Focus Kit with M26VE
    Victor Duncan Mattebox 6.6x6.6
    Sachtler 25
    LVE 7-Jib
    (212) 729.6419 US
    Aug 2009
    Adnan,
    Thanks for putting this test up. I've watched all your other anamorphic lens tests as well. Could you describe your post workflow?
    George Su
    Scarlet-X #754
    Aug 2011
    NYC
    Hi George,
    In Premier CS6, its straight forward. Import the files into timeline and CS6 will automatically adjust the sequence settings to match the Red raw file settings. Then edit as usual and export. If you just want a standard output, choose 1920x784 as export frame size. If you plan to take it to SpeedGrade or other grading program, just export an EDL and you will then be able to grade the raw files.
    The Clutch
    Sachtler 25
    LVE 7-Jib
    (212) 729.6419 US
