Click here to go to the first RED TEAM post in this thread.   Thread: Redvolt degradation.
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. #21
    Senior Member Will Keir's Avatar
    Sep 2009
    California
    very sad indeed. I use the time option instead of % to make me feel better. Maybe 35 minutes per volt.
    Quote Originally Posted by David Bourla View Post
    My Redvolt only charges to 78%. Used maybe ten times?
    Very sad to hear I'm not alone on this issue.
    Will Keir
    Creative Director ~ Jumping Rock Pictures
    Epic X #2482 / R1 #3033
    "Why I choose film?
    The friendships, the adventure, the art."
    Banned
    Mar 2007
    Athens Greece
    I never use my Redvolt batteries until now because I am using the good old Red bricks. But I would like to know from your experience how long the four of them last. As the first one goes away automatically during the shooting changes to the next?? In this case can you unplug the empty one and start charging it?? How long it takes to fully ( whatever fully means) to be charged. Thanks in advance for the information you may share them with me.
    Senior Member Tim Bradley's Avatar
    Sydney Australia
    I have 6 Redvolts and with either a travel charger or the Quad charger I cannot charge the Batteries to over 90%. I have only used the batteries about 5 times each. This makes me think the chargers do not give the batteries a full charge.
    Senior Member Jarek Zabczynski's Avatar
    Poughkeepsie, NY
    In the same boat. Have a 4 pack, none charge past 80% or so.
    Shoot for the Impossible...Then do it.
    Jarek Zabczynski
    Director / Editor / Cinematographer
    Scarlet X - #525 | Epic X - #??? | www.jarek.com | WE'LL BE ALRIGHT (Music Video) | INCREDIBLE (Scarlet Music Video)
    Dec 2010
    Toronto
    I'm sorry, so is there a proper procedure for charging RVs to prevent this? At <80% or whatever, are they still lasting 25minutes-30minutes? Is it just a cosmetic/superficial problem, or are they actually not lasting as long (15-20mins instead of 25-30)?
    Senior Member Stephen Mick's Avatar
    Jun 2011
    Austin, Texas
    Same problem here. None of my Redvolts charge past 80% or so.
    Banned
    Mar 2007
    Athens Greece
    I would very much appreciate it if someone, answers my questions. Anybody PLEASE!!!! THANKS
    Dec 2010
    Toronto
    Quote Originally Posted by Nicos Ambatzis View Post
    Hey Nicos, all of the information you requested is clearly covered in the various pdfs/manuals online for the camera/REDvolts.
    For the sake of brevity I'll answer you, but it's worthwhile to check that stuff out (especially before you buy/rent the stuff). Each redvolt is supposed to last 25-30mins. They are hot swappable, so if you're using a quad or dual battery module, when one does, you can put it on a charger and replace it with a fresh one without turning off the camera. Four RVs would last ~2hours. Each RV takes 1.5-2 hours to charge fully. This means realistically you'd need 8-9 RVs for continuous shooting (assuming you can charge four batteries simultaneously).
    Technically you could get away with only 6 RVs, but you'd be swapping dead batteries with fresh ones constantly every 25-30mins all day, and if you miss a swap you'll probably have a bit of down time... so best bet is to have nine (one for the side handle) and a quad-charger. Kill four batteries in two hours, put them on the charger, swap with the 4 fresh ones (which will take 2 hours to kill, in which time the 4 dead RVs you have charging will be full again and you can swap.) That's the way I would do it, anyway. Conversely, with the dual battery module, you could do the same thing with 6-7 RVs (again, one for the side handle), but then you'd be swapping batteries every hour.
    Senior Member Joe Minuni's Avatar
    Oct 2011
    Orlando, FL
    When i used my Redvolts the percentage on camera would only show average 82% at full charge, however they would consistently last about the 25-30min expected times per battery so I paid no mind to the percentage not being at 100%
    Banned
    Mar 2007
    Athens Greece
    Hi Mike,
    I do appreciate your very detailed mail. I am sorry but I didn't know that I could find all the information on Pdf. I will try to locate them. Sometime you find yourself lost in simple things and your mind (I mean mine) stops. That's where friends come and unblock you. Thanks again for your help.
