Thread: Colour - and gammaspace.
Results 1 to 10 of 10
  1. #1 Colour - and gammaspace.
    Junior Member
    Apr 2011
    Norway
    If you edit your stills in Photoshop you might chose to use the big, nice 16-bit colourspace called Prophoto. But if you print it or send it by mail your pics will look grey and colourless , simply because the printer can’t print all the colours in that colourspace. I suppose your mail-program can’t show them either. For that reason you should down-convert your colourspace to sRGB before you deliver photos (unless you know that your customer can use ProPhoto). And that downconvert should be Perceptual – to move all colours inside the smaller sRGB colorspace - not clipping them away. (Relative Colorimetric is what you might use to convert the other way).My question is:Does it matter what colour- and gammaspace to chose when editing videoclips in Redcine-X for TV?Can you loose colours on your way if clips get converted from a big video-colourspace (Redgamma3 - what is it?? ) to a broadcast-format? I would suppose so?I just ask because too many people tell me that my clips look more grey after I got my RED Epic, using Redcine-X. How can I make sure that my colours look great all the way?
    Aug 2008
    There is no reference standard gamma curve for REC709 compliant video. Typical studio reference monitor calibrations fall in the 2.35-2.4 gamma range vs 2.2 standard for sRGB computer gaphics.
    The best way to insure your footage looks right for broadcast compliant video is to use a properly calibrated HDTV monitor, not a computer monitor, when you do your final grade and encoding pass. This doesn't have to be expensive. I use a sub $400 LG 32" ISF certified consumer LCD TV which has sophisticated calibration menus for use with colorimeters. It is a true 10bit display and provides a much better reference for HD video quality via HDMI input than any sub $1k computer monitor. Purists will tell you that plasma TV's are better, and they are. But the vast majority of people are watching LCD TV's of one kind or another these days. I grade using a calibrated Expert setting and then toggle thru all of the out of the box settings the TV has to see how it holds up under the factory viewing calibrations that most people will pick from.
    Graeme has referred to Redcolor and Redgamma as "REC709 friendly".
    Senior Member Terry VerHaar's Avatar
    Sep 2009
    Silicon Valley, CA
    David - can you point us to this monitor? What are the specific "sophisticated calibration menus" that make it usable with colorimeters? Thanks.
    Junior Member
    Apr 2011
    Norway
    Thanks David!
    If Graeme says it is REC 709-friendly, I suppose it’s mostly the same colourspace in Redgamma3 as in REC 709 and CCIR 601. I agree that you need a monitor that you trust. But this case is actually not about the monitor, but the size of the colourspace. I deliver ProRes-files in HD that get crunched down to a Standard Definition IMX. It doesn’t matter if it looks nice at my computer if the transmitter of the TV-station send out a highly compressed signal with a different colourspace. It’s like when I printed a big panorama from a ProPhoto-file, graded on the best Eizo-screen, showing AdobeRGB. When I picked it up it was black and white whith 50% of the colours! The other colours had been clipped away as the lab couldn’t reproduce that space on their printer.
    Norway
    Asgeir. If you want to prepare colors for broadcast, it is a huge advantage to monitor the signal on a broadcast monitor... :)
    Fits very well with your own example...
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Senior Member Steve Shaw's Avatar
    Mar 2009
    Everywhere
    For calibration info have a look at the various pages on the Light Illusion website:
    www.lightillusion.com
    There is a lot of info there that should help.
    Steve Shaw
    Light Illusion
    steve@lightillusion.com
    +44 (0)7765 400 908
    Skype: shaw.clan
    LUTs, CUBEs + GAMMA CURVEs
    Feb 2010
    Helsinki, Finland
    Quote Originally Posted by Terry VerHaar View Post
    I would assume he means it has a CMS and 10 point grayscale calibration.
    Senior Member Stacey Spears's Avatar
    Sep 2007
    Sammamish, WA
    There is now, it is defined in ITU BT.1886. Its 2.4.
    Aug 2008
    Most of LG's Plasma, LCD and LED models for the last two years from 32" up carry an ISFccc certification. They are all true 10 bit xycc deep color displays. Just look for the sticker or look for it on the spec sheet. Other makes and models with this sticker will have similar menus buried somewhere. The Expert mode menus include selectable color temps, selectable gamma curves, RGB drive and offset adjustments, discrete white balance correction for each of 10 IRE gray scale reference values ( don't mess with this without a colorimeter). There is also a neat built in guided setup wizard that allows a very reasonable basic user calibration by eye.
    Aug 2008
    Quote Originally Posted by Stacey Spears View Post
    Thanks Stacey, good to know.
