Thread: EXPOSURE GUIDE : RAW Level Meter or MONITOR Image ??
Results 1 to 7 of 7
  1. #1 EXPOSURE GUIDE : RAW Level Meter or MONITOR Image ??
    Senior Member George D.'s Avatar
    Oct 2008
    N. California, USA
    As I continue to learn the Red-One, I have noticed that the RAW Level Meter can be misleading as far as exposure is concerned. If there is a lot of black or white in the scene, it will read over or underexposed while the exposure on the monitor is perfect and exactly what I want.
    In the "old days" of film I used a Spectra Incident Meter and NEVER, EVER used the in-camera reflective meter (even if it had one). The best and most accurate exposures were always obtained via the Incident Meter. But, of course, the Red-One is different. So, I just want to make sure I expose the sensor correctly.
    So, should I go with the RAW Meter regardless of how it looks on the monitor, or ignore the meter and expose via the "look" of it on the monitor, as long as it does not show up in the RAW Clip Meter? Or, a combination of both?
    For those of you who have much more experience with this camera than I do, I would appreciate your feedback and thoughts on this. Especially if you've had lots of experience shooting in the field under contrasty conditions.
    Thanks for your time.
    Senior Member Julio Quintana's Avatar
    Austin, TX
    I use the exposure setting (Ev) because it is based off the raw image. Red means lost highlight detail and purple means lost shadow detail. Then you can ballpark your midtones off the monitor. As a final step for increased accuracy, you can use False Color (Vv) which displays green for middle grey and pink for Caucasian skin tones.
    Julio Quintana
    www.juliomquintana.com
    EPIC-X #560
    Canon Lens Package-
    -11-16mm f2.8
    -16-35mm f2.8
    -24mm f1.4
    -35mm f1.4
    -50mm f1.2
    -85mm f1.2
    REDuser Sponsor Martin Stevens's Avatar
    Jan 2007
    Massachusetts
    Don't give up using your Light Meter.
    I still use mine.
    Just be very aware that the highlight latitude with digital is not like film.
    Regards,
    Martin Stevens
    President and Founder of Glidecam Industries, Inc.
    Producer and Director at Metaphoric Pictures.
    Oct 2008
    N. California, USA
    Quote Originally Posted by Martin Stevens View Post
    I still use mine.
    When I first got the camera, I did the same thing. But, it quickly became apparent that the ISO of the camera did NOT match the ISO of the meter, which has always seemed strange to me.
    Yes, Red-One digital is very similar to shooting with positive film. Overexposing is lethal.
    Thanks.
    Aug 2008
    You have to profile the camera to the meter. Shoot a Kodak 18% gray card or a grayscale chart. Find the exposure that gives you a 118,118,118 8-bit middle gray value for daylight, measure the light level with the incident meter and set the meter tables to match your camera exposure setting. Do the same for tungsten. Meter readings should match up after that. I would use the linear camera RGB default setting in Redcine for this as you are profiling the sensor to find its native zone 5 middle gray ISO.
    Oct 2007
    now in Rome, Italy.
    +1, to the Nth.
    Oct 2010
    Winnipeg, Canada
    Solid guys.
