Thread: Realtime 5K full debayer playback?
Results 1 to 6 of 6
  1. #1 Realtime 5K full debayer playback?
    Jan 2009
    Grand Rapids, MI
    So I have what I think is a very fast computer. 8 core at 2.4GHz mac pro with 32GB of memory and a Red Rocket card. I also have an Nvidia GTX285 for CUDA applications like Premiere Pro and Resolve. For resolve I switch my monitors to a GT 120 and use the GTX 285 as my GPU.
    Why would my system choke playing back 5K footage at full debayer? I won't mention any HDR footage, forget it. It can play 4K OK and any lower resolution plays fine at full debayer.
    Could the Rocket work better at 5K if there were a firmware update maybe? Does the current Rocket just not handle 5K well at all? I would like to think that my nearly $5000 investment would allow me to show off a bit and prove it's worth a bit more.
    Does anybody else have issues playing back 5K at full debayer? Has anybody made it work?
    Senior Member Josh Beadle's Avatar
    Sep 2011
    SoCali
    I have a 2010 Mac Pro 12 Core with a 800mbs Raid and RR card - plays 5K/Full fine when given a couple seconds to buffer ahead
    Josh
    Epic-M 1388 aka "Black Sheep"
    ATV FamFun
    It's not your camera's fault:
    http://www.youtube.com/watch?v=jJm2EGNIod0&feature=related
    "Your first 10,000 photographs are your worst"
    Henri Cartier-Bresson
    Dec 2009
    Montreal
    Hey Josh!
    How does that work within an edited timeline? Does it stutter at each cut or only at the start of playback?
    Is there a difference depending on in what software you do the playback?
    EPIC X #606
    Sami Sinervä
    DP / Cinematographer / Filmmaker
    www.nipcat.se
    Mar 2008
    New York City
    resolve won't do full res , you need 2 RR and 3GPU for that ,
    i assume is because when doing Full res it pass does a trued 5K frame to GFX that than get scaled to HD ,
    i think that RCX PRO have not as sophisticated internal processing going on , and so can handle it better , also i believe that RCX pro even tough is debarring full is is scaling the resolution at 1/2 while playback ...
    g
    It does indeed matter which software you are using. The Rocket always does a full-resolution, full-quality debayer of each frame. Everything runs through the RED SDK API's, the rocket basically works by feeding it a single compressed R3D frame, it returns a full quality frame decoded at full size that has been scaled to the desired output size. Beyond that, everything else is up to how the software developers create their app to use this. Some provide better caching, some have better scheduling and load balancing os to what they do when or when they request frames from the Rocket, some provide GPU acceleration for operations taking place after the Rocket returns each frame. Some make better use of all your CPU cores, etc... There are so many factors that influence this.
    - Jeff Kilgroe
