Click here to go to the first RED TEAM post in this thread.   Thread: Underwater Scarlet / Gates Deep Epic Footage
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 50
  1. #31
    Senior Member Chase M. Wrenn's Avatar
    Aug 2010
    Agreed, looks great, awesome job.
    SCARLET-X #65: "Ruby"
    www.vimeo.com/Chasefox
    www.QuiverDigital.com
    Anyone interested in getting their work on iTunes, Amazon, Google Play, etc...let me know.
    Senior Member Jon Shaw's Avatar
    Apr 2008
    Sydney, Australia
    Thanks again guys
    Jon Shaw
    ginclearfilm
    Sydney
    Australia
    Underwater production and services including Gates Deep Epic
    www.ginclearfilm.com
    Senior Member Matthew Scott's Avatar
    Nov 2008
    Melbourne, Australia
    Quote Originally Posted by Johnny Friday View Post
    ...i'd much rather shoot an EX1 vs. going direct to external prores record device. You'll get much better picuture from the start with the EX1, Z1 or P2....or any of those cameras. Your of course WAY better off shooting RAW and taking time to work the images in a proper color monitoring realm--now here's where it becomes a BLACK ART or BLACK MAGIC---i know now how B.M got their name....I can go on about this end of things....but i'll keep it to that.
    Are you kidding me? My 10-bit prores files from the Scarlet are 17.9 billion times better than anything I ever recorded from an EX or P2....and let's not even put a Z1 into that equation. The HDSDI 1080p output from a Scarlet/Epic is astonishing, and 10-bit ProRes is joy.
    Great footage BTW Jon!
    Junior Member
    Oct 2010
    NYC
    wow! gorgeous my friend!!! I really enjoyed this.
    Senior Member Johnny Friday's Avatar
    Feb 2007
    La Paz, Baja Ca. Sur, Mexico
    Quote Originally Posted by Matthew Scott View Post
    I'd suggest you actually use a recorder and record out to say a pix 240 @ 422 and a flat raw look and then tell me otherwise....sure i probably exatureted a bit...but would shoot a 750 or 900 before EVER considering shooting my epic to an external device recording prores--which i've done on three occasions and there's no reason to shoot on epic or scarlet if you are just making prores files out of your sdi....makes no sense at all and makes the post process a pain.
    John Friday
    La Paz, B.C.S., Mexico
    www.bajaproductions.com
    EPIC M & 2X for 3d & Deep Epic Underwater Housing
    RED MX with SSD & Underwater Housing
    Apr 2008
    Sydney, Australia
    Totally agree with Johnny, also when working with underwater footage trying to correct a flat image @422 is hard to make it look good.
    Jon Shaw
    ginclearfilm
    Sydney
    Australia
    I'll echo Mike, here - how fares our fair cameras in confined space with hot little sensors? Does the water temp keep the system cool? Also, what batteries can squeeze into the housing, Gates and Aquavideo? Are we restricted to REDVolts or possibly AB Dionic 90? And finally... have you experienced or heard of condensation being an issue?
    Thanks!
    Chris ~
    Apr 2008
    Sydney, Australia
    Temperature is fine, I spent 10 hours in a 31 C (nearly 90F) pool shooting a TVC and the camera was running the whole time, it never overheated once. I have the fans set manually to 100% on standby and 75% on record no problems at all. With regards to batteries I am using GMP 160's and I get two and half hours run time. I haven't had a issue with condensation but best practice is try and close the housing in an aircon environment or at least cool and dry. PVC housings suffer much worse for fogging that Ali ones. Plus I think having the fan on in the camera helps solve the problem also.
    Jon Shaw
    ginclearfilm
    Sydney
    Australia
    Oct 2008
    Vienna
    wow. awesome shots. my mouth is still wide open...
    Norbert Jalitsch / Vienna
    dsmworx.at / digital still motion worx
    norbert.jalitsch@gmx.at
    red epic-x / #02576 "istvan"
    5" pro touch / bomb oled / redmote / Ti Canon @ PL Mount / cinemods leica-r mount / approx. 1 1/2 TB SSD's / pix240i / rpz 18-85 / leica r´s: 15/19/24/35/50/80/135/180/250/350 / Rokinon 8/14/25/35/85 / RTMotion 3-Channel Wireless FIZ / small hd dp6 / red dsmc 15mm lw & 19mm studio support / red pro mattebox / chrosziel 456 acad. triple mattebox /
    Apr 2008
    Sydney, Australia
    Thanks Norbert
    Jon Shaw
    ginclearfilm
    Sydney
    Australia
