Click here to go to the first RED TEAM post in this thread.   Thread: BNC out doesn't function!!
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1.   Click here to go to the next RED TEAM post in this thread.
  #11
    Red Team Stuart English's Avatar
    Irvine, Ca
    Please send RED tech support a camera LOG file...
    Workflow Wizard
    Apr 2011
    Toronto, |+|Canada
    Log file sent in but crisis averted on my end.
    I have Panasonic BT-LH80WP and BT-LH910G as onboard/portable monitors and BT-LH2550P as client monitor. This morning I was prep'ing with the older LH80WP that was on the shelf and kept getting the 'unsupported signal' error. Plugged the video into the Blackmagic board of my brand new on-set computer and just saw black. Tried different cables, no luck.
    Unpacked the other two monitors and I have picture. Went into the BM card settings and checked the "use 1080p instead of 1080psf" option and I am getting picture to the computer too. Looks like I was bitten by the p/psf bug.
    No, I instaled the 3.2.13 firmware and nothing works. I'm with the same problem in two scarlets.
    Senior Member Johnny Friday's Avatar
    Feb 2007
    La Paz, Baja Ca. Sur, Mexico
    [QUOTE=Paul J Went into the BM card settings and checked the "use 1080p instead of 1080psf" option and I am getting picture to the computer too. Looks like I was bitten by the p/psf bug.[/QUOTE]
    Didn't the new build say something about only 1080p being supported? I recall seeing this on that new build no Psf any longer....
    John Friday
    La Paz, B.C.S., Mexico
    www.bajaproductions.com
    EPIC M & 2X for 3d & Deep Epic Underwater Housing
    RED MX with SSD & Underwater Housing
    Senior Member Vigen Vartanov's Avatar
    May 2007
    Tbilisi , Georgia
    SAME PROBLEM HERE !!!!!!
  6.   This is the last RED TEAM post in this thread.   #16
    Irvine, Ca
    We have never offered PsF output on any of our cameras, our HD-SDI outputs are true Progressive only. So please set your monitoring accordingly. If the monitor says "unsupported format" it's a good bet this selection is what the issue is. Most HD-SDI chip sets do support true Progressive mode as well as the interlace based PsF mode, but some don't which is unfortunate.
    If you are seeing issues with 720p out, it may be because your monitor is only capable of accepting 720p / 50.00 or 720p / 59.94 fps. In that case verify that the HD-SDI out from the camera says one of those - it's possible it may be set to 720p / 23.98 and again there are some HD-SDI chips sets that won't accept that signal format.
    Workflow Wizard
    I seem to remember a RED guy saying that the HDsdi is now 3G - could be your monitors only support 1.5g....
    Sidney Lexy Plaut
    filmmaker.
    Epic Package. Complete set of rehoused Cooke s2&3 series 2000... and lots of toys.
    www.vimeopro.com/sidneydp/sidneydp
Tags for this Thread
View Tag Cloud
