Thread: Better for features: RPP 300, or converted Nikon 200/2
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    Banned
    Aug 2010
    Quote Originally Posted by Shane Kelly View Post
    You'll have to explain that one to me.
    Crop Factor
    The image produced by the Heerbrugg is ~3 times the size of the Red Epic Sensor, thus only recording the cropped area of the image projected by the lens
    Feb 2007
    Austin,TX
    It's still a 98mm lens, though. It will be a 98mm lens on any camera, crop factor has nothing to do with it. A medium 50mm on a red is still a 50mm and will give the same approximate field of view. You may only be using the center of the lens but it's still a 50mm.
    take a look at: http://blog.abelcine.com/2010/05/14/...ens-is-a-lens/
    http://shanefkelly.com
    Epix-X#607
    Wise men talk because they have something to say; fools, because they have to say something.
    Plato (427 BC - 347 BC)
    Jan 2009
    New Orleans
    I assume we're referring to an older 200/2 AI-s and not the modern AF-S?
    I have no experience with that lens, but for whatever it's worth the modern one is absolute magic.
    Feb 2007
    Austin,TX
    Quote Originally Posted by Lee Saxon View Post
    Yes, the older one is the one that used to get converted. It's a great lens as is the 300/2.8.
    Epix-X#607
    Banned
    Aug 2010
    Where am i claiming it's a 300mm lens though? I'm merely stating that the image magnification will be similar to using a 300mm lens. ;- )
    Senior Member Yousuf Abbasi's Avatar
    Jun 2009
    San Diego
    Shane, he's talking about the behavior (field of view) of that particular focal length when put on the EPic. Obviously a 98mm lens is always a 98mm by design and that wont change, but the field of view WILL change when you switch sensors of varying sizes. As Steven pointed out, the image circle diameter of the Heerbrugg is ~3x the RED epic sensor diameter, which would mean the field of view of that 98mm lens is equivalent to the field of view you would obtain from a 300mm lens with an image circle diameter of roughly the RED epic sensor diameter.
    When people say a 50mm is a 50mm is a 50mm, they are talking about the mechanics of the lens itself - not the field of view or crop factor (which vary among cameras/sensors).
    Senior Member albert rudnicki's Avatar
    Toronto-Montreal
    One more for Nikon 200 f2.
    Its gorgeous and sharp even wide open.
    Worm look
    Matches cookes nicely.
    Nov 2009
    depends, do you want to do a closeup of your talent at 60 feet away from you or 100 feet away from you hahahahahahahahahahahahahahahahahahaha
    Sorry - couldn't help myself.
    Feb 2007
    Austin,TX
    Quote Originally Posted by Yousuf Abbasi View Post
    I strongly disagree. If you put a 98mm lens on a epic, no matter what format it was designed to cover, it'll look like a 98mm, not a 300mm. It may have been designed to cover a larger sensor but it will still behave like a 98mm on an epic, not a 300mm. There's no way around that.
    I have a zeiss 180/2.8 that was designed to cover medium format that was converted to PL. It has the same field of view as my 180/2.8 nikon on my epic. It's a 180mm and will always be a 180mm.
    200mm nikon f/2 is still a great lens though.
    Epix-X#607
    Dec 2008
    San Diego, CA
    Shane..no.
