Click here to go to the first RED TEAM post in this thread.   Thread: Release Camera Build 3.2.16
Page 18 of 19 FirstFirst ... 8141516171819 LastLast
Results 171 to 180 of 189
  1. #171
    Feb 2007
    Netherlands, Amsterdam
    Quote Originally Posted by Wim Verbeek View Post
    Hoi Robert,
    Good to know that everything works fine!
    I am planning to buy the Pix240 later this year. ...first Red's Nikon Mount (planned release in august).
    Just upgraded Scarlet-X and Redmote to current releases, no problems found.
    Best, Wim
    Good to hear this Wim.
    Pix 240 is brillant to work with Scarlet and Epic!! Customers lov it. Best regards Robert
    Robert M. Berger NSC
    Director of Photography
    Epic-X "ED" 00274
    www.camlight.nl
    Amsterdam
    The Netherlands
    Senior Member Johnny Friday's Avatar
    Feb 2007
    La Paz, Baja Ca. Sur, Mexico
    Quote Originally Posted by Frazier Nivens View Post
    Johnny, did you install the new Antenna yet? My REDMOTE hasn't worked to control camera since when I put the camera inside my housing, start stop record goes to the yellow dot and then I have to do a hard reboot of the camera. Haven't had the white screen yet? Still trying to troubleshoot my issue.
    HI Frazier, i moved my camera back to the previous build because of the screen problems....the camera i am using now does NOT have the new antenna on it......i have another camera with the antenna installed, but have yet to use that camera since it just came back from red and i'm shooting only underwater this week and that upgraded camera was meant for above water.
    I will likely here your reports first since i'm back to the older build and now will wait for a new build with fixes---the antenna issue is good to hear. I cannot think of any good reason the antenna should have anything to do with the new build?
    John Friday
    La Paz, B.C.S., Mexico
    www.bajaproductions.com
    EPIC M & 2X for 3d & Deep Epic Underwater Housing
    RED MX with SSD & Underwater Housing
    Apr 2011
    Toronto, |+|Canada
    My bugs:
    Switching from the touchscreen to the OLED EVF (hot plug) often results in getting nothing but the test pattern and requires a reboot to get live image back in the viewfinder.
    When HDRx is enabled movement in the frame causes jitter in the OLED EVF.
    Hi Red team,
    What exactly is this fix: "Fix for RED EVF connection problems"?
    I'm still using the "old" Redone EVF and I still have "red flashs" when connecting it with the Epic-X (is that fix not about that)?
    thanks a lot,
  5. #175 hmm
    Jul 2010
    Stamford CT
    My DP just told me to tell you guys that the black white screen issue is not fixed. Thanks
    Senior Member Jarek Zabczynski's Avatar
    Poughkeepsie, NY
    My bugs:
    Made my Scarlet a brick.
    Had my camera at RED all week. They are sending it back now. Was told certain cameras had issues with this firmware build and a new one is being released very soon to address all these issue. Personally, I would stay away from this build like the plague.
    My baby is coming home!
    Shoot for the Impossible...Then do it.
    Jarek Zabczynski
    Director / Editor / Cinematographer
    Scarlet X - #525 | Epic X - #??? | www.jarek.com | WE'LL BE ALRIGHT (Music Video) | INCREDIBLE (Scarlet Music Video)
    Senior Member Dominick Pietrzak's Avatar
    Sep 2010
    NYC
    Yeah still getting that annoying white screen at boot up.
    Removing the RedMote and rebooting seems to do the trick most of the time. Doesn't fail to scare me each time though!
    Quote Originally Posted by Jarek Zabczynski View Post
    And it's still available on the downloads page. WTF is going on?
    Mark Pugh LA,NYC, and AUS.
    www.markpughfilms.com
    Several EPICs...
    Senior Member Jon Carr's Avatar
    Aug 2009
    NYC
    My bugs:
    How was it turned into a brick? What was the problem?
    Dp Reel
    http://www.visualcinema.com/reels/
    Rentals in NYC
    http://www.visualcinema.com/rentals/cameras/
    EPIC-X #____ (soon to be Dragon)
    Canon & PL mount, Canon 16-35, 24-70, 70-200, Rokinon 24mm, 35mm, 85mm, & everything you need to shoot RED!
    It's REDcode or no code...
    Senior Member Tehben Dean's Avatar
    May 2009
    Alaska
    Trying to upgrade REDmote to 3.1.8 but it's showing as a telephone in system>Network and I can't enter an IP address etc....?
    Also the EPIC Users guide is messed up:
    TEHBEN DEAN - stills & motion
    EPIC-X #557
    www.tehbendean.com
    I love to shoot beautiful things with cameras...
