Thread: Again, not reading RMDs right at import
Results 1 to 5 of 5
  1. #1 Again, not reading RMDs right at import
    Norway
    Hi
    I have tried to contact DaVinci support about this, but no response so far...
    Issue is that sometimes, resolve seems to get stuck on one RMD and applies that to the full project.
    Last time trhat happened, I was low on time and just figured this was my fuckup.
    This time, though, I have had time to check, and it is a resolve mess.
    Here is the same clip in resolve and RCX
    Resolve
    RCX
    So... I did a full fresh conform after making sure the RMDs were in the R3D folders, and still all clips get the wrong settings.
    You'll have to rightclick on the image and choose "show image" to see the settings...
    Wassup?
    G
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    ... and if you choose "Decoding Clip using": Camara metadata ?
    "¿Render?... beer time!
    two Epic-X, 24"FSI 10bits, 50"Panny, Some computers; Work as Colorist, DIT and Tech Counselor.
    Norway
    That kinda worked. AND reset the clip metadata to the "right" settings...
    Ouch
    G
    Twitter: gunleik
    Dec 2009
    Montreal
    You have to re-import your media - Resolve only remembers one settings per clip, per project - then it stay stucks on that - it doesn't matter what you do in Redcine - you can only change it in Resolve itself.
    Only a fresh project will fix it, or you could copy the media to a new drive and replace it. There is no "reload from RMD" function like in Premiere.
    Norway
    This time around I had some time to play with it, and batch setting the clips to another setting, seemed to make resolve read it right...
    G
    Twitter: gunleik
