Thread: My PC - what to upgrade.
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 My PC - what to upgrade.
    Junior Member
    May 2012
    Hi, I'm fairly new to the world of RED. I get my first camera this week, a RED One.
    I built a new PC for myself a few months ago, and I'm just wondering how it would go with 4K video. I'm currently using CS 5.5.
    The specs are:
    2600K CPU OCd to 4.4GHZ
    16gig RAM
    GTX 680
    Gigabyte Z77-D3H MB
    A few SSDs etc.
    I guess the things I could update could be, adding more RAM, adding another GTX 680, and updating the CPU. What do you think?
    Thanks,
    Tim.
    Apr 2011
    Toronto, |+|Canada
    First thing I'd get is the Red Rocket card. 4K footage will playback as if it's 1080p in Premiere when you have a RR card.
    You can also get an Nvidia 6000, that also plays 4k back real time, and it helps a lot with rendering in After Effects , Maya etc.
    Junior Member
    May 2012
    Thanks, the 6000 looks good. At the moment there's someone on eBay selling new ones for around $1830, which is a lot cheaper than the Red Rocket.
    Jul 2007
    Marseille/France
    With your configuration,you can work in real time at 1/2 resolution with 4K R3D in CS5.5;more ram and an other graphic card won't change anything.For the CPU to achieve real time 4K full resolution,even 2 latest 6 core CPU won't be enough.
    http://planb-red.com
    Red Epic camera rental
    Location caméra Red Epic
    Marseille
    Junior Member
    May 2012
    Aah ok, thanks. I think I'll save my pennies for a Quadro 6000, along with some batteries, some more glass, and another RED Mag. :-)
    Jul 2007
    Marseille/France
    The Quadro 6000 has 448 cuda cores like the GTX 470...
    The best actual card for CS6 is the GTX 580 with 3go RAM.
    Since the R3D decoding is made by the CPU you will still work at 1/2 resolution which is 2K!
    For full hardware 4K decoding,the Rocket is the solution.
    Marseille
    Feb 2010
    Helsinki, Finland
    Indeed, you should be able to easily run at 1/4 res as long as your storage is fast enough, and might be able to run at 1/2. For full res you need a rocket.
    Skip the Quadro and change the 680 to a 580 to get the most out of CUDA processing. I don't think Adobe software can use more than one GPU, so you wouldn't get anything out of adding another 680.
    I'm building a new station with
    dual 8 core 2.4gh
    supermicro x9dai
    64 gb ram
    quadro 6000
    ssd system drive
    Ill let you know how it performs with r3d's, hopefully by Friday.
    Senior Member Paul Toth's Avatar
    Nov 2008
    YYC
    The 1/4 & 1/2 res is not the resolution you are actually working in, but the rez you are viewing. You are still working in the original res of what was shot.
    I'm running a dell machine that's 5 years old that features 2 Xeon processors with 24 gb ram on windows 7 with a quadro fx 4800 nvidia card and CS6 and I have no problems working with or viewing my 4k footage.
    Producer, Cinematographer, Adobe/Avid Editor, Musician
    Scarlet #1950
    YYC
    My Blog at AdvanceHDTV.com
    IMDB
    YouTube.com: AdvanceHD
