Hey all! So I'm almost getting the hang of REDCINE-X HOWEVER, I'm having a hard time copying the look from one clip and applying it to all the other clips for a continuous look. Any help would be greatly appreciated!
Thanks!
Tad
Thanks!
Tad
There are a couple of ways to apply looks to multiple clips. If you haven't yet, you should check out the look panel tutorial at red.com.
Tadeo, you may already know this, but I was often tripped up by it: you have to create a bin and move your clips into it. Once your clips are in the bin, you should be able to copy and paste looks from one to the other.
Once you have a look you like, you can save it by pressing + in the looks tab. Then select where you want it to be copied to (like all selected in timeline for example). Press apply and voila. This way you can also easily test older looks on new footage without having to go through older projects. Your saved looks always appear in each project.
I simply select the clip which has the looks I want, I COPY and then select the clip/s I want the looks transferred to and PASTE. Unless I'm getting the question wrong...
Thanks! I'm gonna give it a whirl based on all the feedback! Thanks all!!!
