Thread: DNxHD from RedCine into Avid MC6 - PC
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 46
  1. #31
    Rory,
    I am sorry to hear about your problem. I have been making dailies / etc. with REDCINE-X, Avid MC 5.x 9 weeks this year more or less exactly like the other gentlemen described: export MXF / AAF DNxHD36 / 1080p from redcine-x (pro), move the created MXF to the AVID MEDIAFILES/MXF/1 folder and import the AAF to a bin. If you put new MXF in the MEDIAFILES Folder Avid sorts it out while starting up, as soon as you import the AAF the media is online. you don't need to move the AAF anywhere, only the MXF.
    have to you tried to export a Quicktime DNxHD from redcine-x and (fast) import this file to Avid?
    is there a avid media database in your Mediafiles Folder?
    have you tried to delete your mediadatabase and restart Mediacomposer?
    all the best,
    martin
    is there some plugin that needs to be installed for Avid to read MXF DNxHD files coming from RedCineXPro?
    I honestly just can't figure out why this won't work.
    Rory Hinds
    Director / DoP / Colourist
    Mine Films & Mountain DI
    http://www.minefilms.com
    UK, USA, CANADA, EUROPE & SOUTH AFRICA
    IATSE 669 Director of Photography
    VFX, Grading & Finishing
    Aug 2007
    Boston
    I am offering again to call you and walk you through it if you think that will help.
    Michael
    Ernst Lubitsch
    Aug 2007
    Boston
    Or Skype and share desktop so I can see what you're doing.
    m
    Ernst Lubitsch
    Senior Member steve green's Avatar
    Jan 2012
    Thousand Oaks, Ca
    Hey guy,
    I'm on a shoot right now and the producer has a what is probably a simple question for all you (but for me, not so much). We've shot Epic R3D files and Alexa ProRes 4444 files and need to edit them in the same sequence on Avid. Also we plan to color correct on a Baselight. What's the procedure for doing the edit and final color correction with the native files?
    Aug 2007
    Boston
    Transcode both via Resolve, or R3D in REDCINE X and ProRes LogC with 709 LUT in Resolve. Both applications use Avid's SDK for native MXF wrapped DNxHD so metadata will be consistent; filename will be listed in the TAPE column. Final conform and correction will be done via EDL or AAF into Baselight pointing back to the original files.
    Michael
    Ernst Lubitsch
    Jan 2012
    Thousand Oaks, Ca
    Quote Originally Posted by MichaelP View Post
    Michael
    Thanks, Michael, I think that's what we're after....A way to color correct the R3D's.
    Quote Originally Posted by roryhinds View Post
    Rory,
    One thing you might just try is making sure to copy/paste the MXF files generated by RCX into the AVID mediafiles folder, rather than cut/paste. It took me ages to work out that this seemed to be a necessary condition, at least on my system.
    I have posted about this before but no one has been able to explain why, might be worth a quick try though.
    Chris
    thanks Chris... unfortunately that didn't help me as its still can't import the RCX files and show them in Avid.
    Hopefully Michael can help me.
    Rory Hinds
    Aug 2007
    Boston
    Just set up a time where I can Skype and share desktop and show you how it's done, or watch and see what you're doing.
    Michael
    Ernst Lubitsch
