Thread: Need advice. Nikon or Canon mount?
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    Senior Member Eric Haase's Avatar
    Mar 2009
    Quote Originally Posted by Miltos Pilalitos View Post
    OK after a lot of lens comparisons and thought I concluded that for someone with no previous DSLR lens collection it's best to go Canon mount for the Epic (although I consider myself to be a Nikon guy).
    As for lens, I think that the Canon EF 24-70mm f/2.8L looks excellent optically and will suit my needs! Does anybody know what the EPIC's cropping factor does to this lens? The 24-70 is equivalent to what in cinema world?
    Its a 24-70. So on your red camera, at 24mm it will yield the same field of view as your red zoom when set to 24mm.
    Eric
    cinematographer
    www.ericjhaase.com
    Senior Member Miltos Pilalitos's Avatar
    Jan 2007
    Athens, Greece
    Cool! :D
    I am slightly old school. Ages ago when we were using lenses for 35mm cameras on S16 cameras we had to take into consideration the change in focal length. The canon lens is for a Full Frame sensor so I thought that something similar applied there.
    Miltos
    www.pilalitos.com
    EPIC-X #418, RED-MX #1473, RED ZOOM 18-50, RED ZOOM 50-150, Duclos Tokina 11-16
    Senior Member Stephen Williams's Avatar
    Europe
    Cool! :D
    I am slightly old school. Ages ago when we were using lenses for 35mm cameras on S16 cameras we had to take into advantage the change in focal length. The canon lens is for a Full Frame sensor so I thought that something similar applied there.
    There was never a change in focal length when you use a 35mm lens on S16 in fact with modern lenses they are identical however the extra wide ones only cover S16. A standard set for S16 the no's will be half however!
    Epic M owner
    Jan 2007
    Athens, Greece
    Well, the focal length might have stayed unchanged but a lens for a 35mm camera was giving as a narrower field of view on our s16 cameras.
    Miltos
    www.pilalitos.com
    Senior Member Aleksandar Colancevski's Avatar
    Mar 2008
    Skopje, Macedonia
    Thanks for the offer Aleksandar! That beer sounds tempting. :D
    If we leave focusing issues aside for a second, how well do your Nikons perform optically on the Epic?
    Well, if you focus it right with 5.6 to 8 stop, you get a decent picture. I don't believe that Canons are worse that much that you will notice.
    Then again I think better to be in focus on "worse" lens then out of focus on "better lenses.
    I would take Canon 24-105mm which is solid replacement for RED 18-85mm and de noise in post if sometimes the lens it too slow because of its f4 minimum stop.
    Senior Member nick allsop's Avatar
    Jun 2007
    London
    The mm don't change it's just that the field of view changes when used on different sensor sizes. So when shooting 2 k the field of view is like using 16 mm as the sensor crops in. A full frame SLR lens would have the same fov as a pl mount lens on a red. But if you put it on a full frames SLR it would have a wider fov.
    Nick Allsop - Red Technician (DIT)
    Reducated at Red Studios Hollywood
    TA @ REDucation UK
    Kinetic Cameras - RED camera hire
    RED MX #1152 EPIC X #393 & #1133
    become a Fan of Kinetic Cameras on Facebook
    http://www.facebook.com/pages/Kineti...463949?ref=mf#
    to see behind the scenes photos of RED cameras in action.
    For your focal lens dilemmas, check this: http://www.abelcine.com/fov/
    Victor Lazaro - Steadicam / Camera Op
    --- www.victorlazaro.com --- @LazaroFilm ---
    Jan 2007
    Athens, Greece
    Quote Originally Posted by Victor Lazaro View Post
    Thanks for the link Victor.
    Miltos
    www.pilalitos.com
    Feb 2011
    Bangkok, Thailand
    I recently acidentally discovered that if you put your follow focus on top rods it will reverse its focus direction. Good cheap solution to those of us who occasionally use nikon lenses without a follow focus that can change focus direction. Just pick up an inexpensive top rod mounting solution from x.
    Danai Chutinaton
    Scarlet X #2264
    Feb 2011
    Bangkok, Thailand
    At the moment, I believe the convinience of the electronic Canon mount is the way to go for one man band road trip. Get a lens with image stabilization because that works really well! I just did a shoot with the Canon EF-S 17-55 f2.8 lens. And it was a joy to use hand held. but make sure u bring you camera to test out the lens when you buy as not all lenses are "profiled" so not all of them work perfectly with the canon mount.
    Danai Chutinaton
    Scarlet X #2264
