Click here to go to the first RED TEAM post in this thread.   Thread: Saving Looks to Camera Video Tutorial
Page 6 of 6 FirstFirst ... 23456
Results 51 to 55 of 55
  1.   Click here to go to the next RED TEAM post in this thread.
  #51
    RED Bomb Squad Sean R.'s Avatar
    Aug 2007
    Quote Originally Posted by Frank Martin View Post
    Still hoping for an answer. what is the best method of removing the applied look from camera . Under the preset menu we could not seem to undo look. only way was to reset factory look then reboot. Feels like we are missing something. Also can you import multiple looks into camera?
    Yes you can import multiple looks. Easiest thing to do (to get back to home base) is just save a default look(s) to camera and it will be there to return to along with your other LUTs.
    Sean Ruggeri
  2.   Click here to go to the next RED TEAM post in this thread.
  #52
    Aug 2007
    Trent's on it (I started response and then got interrupted :) and his suggestion is easier than mine (if you just need a single default look to return to).
    When you are just removing the look vs. the entire system restore your other settings (such as REDcode, resolution, etc) will not return to defaults as well.
    Sean Ruggeri
  3. #53 Thank You
    Senior Member Frank Martin's Avatar
    Jun 2008
    Miami/NY,NY
    Got it.Thank you both!
    Frank Martin
    Powerhouse Filme
    IATSE 600 DoP
    www.fmartin.com
    Sep 2008
    Vancouver, BC, Canada
    Are the looks saved internally on the camera after applying them the first time? Or do you have to load them everytime you change the cards?
  5.   This is the last RED TEAM post in this thread.   #55
    Quote Originally Posted by craigjkharris View Post
    When you import a look to the camera it is stored on the camera and you can go back to the dialog and see a list of looks on camera (and a separate list of what looks are on the media). Note that the looks on camera are lost after an upgrade.
