Thread: Red Rocket + Sonnetech Thunderbolt Adapter EASY?
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 Red Rocket + Sonnetech Thunderbolt Adapter EASY?
    Oct 2011
    Los Angeles, CA
    I am about to buy a couple Red Rockets and Sonnetech Thunderbolt Adapters. I don't have a lot of experience with either of these. Are they fairly easy to use? I will be using them on current generation iMacs with CS6.
    Epic-M #1364
    You will need to buy the larger "Pro" model of the Sonnet Thunderbolt to PCIe expander to fit the Rocket card.
    What is it you're trying to accomplish specifically? You'd be amazed at what you can accomplish with a properly configured iMac or Macbook Pro system, CS6 and NO ROCKET. I would make sure that iMac has 32GB of RAM in it, an SSD for primary storage and a good external RAID (Thunderbolt) first. Only bottleneck you should encounter then is for high-quality transcodes or final renders. If you're doing mostly transcodes, this probably isn't the most effective solution.
    - Jeff Kilgroe
    Oct 2011
    Los Angeles, CA
    Thanks Jeff, I currently have an iMac with an SSD, 32 GB RAM, and working from Thunderbolt drives. The problem is that I have to step down to lowest playback resolution in Premiere. It doesn't look that great and would love to be able to hit half resolution playback.
    I was planning on purchasing the Echo Express Pro Thunderbolt Expansion Chassis. I believe this is the one that fits the Red Rocket, correct?
    Epic-M #1364
    Jeff, would you say adding a Rocket and a good NVidia gpu into that box that it would boost that iMac significantly? Esp in CS6?
    Using the second tBolt port for data and other peripherals?
    Jason Diamond
    The Diamond Bros.
    @jasondiamond
    EPIC-M 512 & EPIC-X 1423 Ti PL and Canon Mounts.
    Leica-R Duclos Cinemod 19,24,28,35,50,80,100
    REDRockets and Sonnet TBolt Rigs Avail.
    Avail NYC and anywhere trains, planes and automobiles go.
    Senior Member C.H.Haskell's Avatar
    Brooklyn New York
    Is it safe to say a rocket will accelerate my CS6 experience?
    C
    Clayton H.Haskell, ICG
    cinematographer IATSE Local 600
    NYC | LA | PARIS | LONDON | BERLIN |
    EPIC-M - ARRI MASTER PRIME & HAWK ANAMORPHIC Kits available today
    LEICA Summilux-C Primes Coming Soon.
    Twitter | EPIC REEL | haskellfilms
    The Mac OS intentionally doesn't support external pci-e graphics cards (Nvidia card won't help), a red rocket card would work well since it only uses x4 lanes for playback and x4 lanes for transcodes and TB is comprised of x4 lane multiples (two x4 or four x4) depending on the TB controller.
    Senior Member Paul Ellington's Avatar
    Aug 2011
    New York City
    Dear Mr. Kilgroe,
    I own a 12TB Promise. Right now its storing lots of old projects. I was considering getting a cheaper Raid and erasing whats on the promise once it's backed up. This is the 3rd backup in the chain. So after the Promise is emptied there would still be 2 copies of everything.
    Thanks for any advice.
    - Ellington
    Paul Ellington
    director/dp & writer
    NYU GRAD FILM • CLASS OF 2013
    | ALL AROUND THE WORLD |
    RESUME
    Senior Member Chris McKechnie's Avatar
    Mar 2011
    Orange/LA County
    Get a MAXX Digital Edit Vault...like $300 for 2TB. Connect that via esata to the Lacie Esata/TB Hub ($200). Cheap and fast backup storage solution. :-)
    Chris McKechnie
    DP/Cinematographer/Editor
    web: http://digitalcinemaguy.com
    RED Epic M Package
    Canon L Series Primes/Zooms
    Steadicam, Sliders, etc.
    Oct 2011
    Los Angeles, CA
    Anyone have a response as to whether or not a Sonnetech PCI-e thunderbolt adapter plus + Red Rocket is user friendly?
    Epic-M #1364
    Aug 2011
    New York City
    Quote Originally Posted by Chris McKechnie View Post
    My 12 tb is full
    Paul Ellington
    RESUME
