Thread: Seeking advice on International travel (US-Germany)
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1 Seeking advice on International travel (US-Germany)
    Senior Member Frank Weeks's Avatar
    I could use the collective knowledge of our esteemed brotherhood as I prepare to venture overseas for a shoot in Germany. I've been doing this for 30 years but international travel on a tight budget is something new.
    I know there have been a number of threads about airfare in general over the past few years but they can be tough to hunt down.
    I know enough to ship batteries to avoid any of the potential problems they present.
    I will be traveling Delta and will attempt to restrict my cases to 4 checked and 2 carry on. The size and weight restrictions of checked baggage is not always clear but I believe it's 50lbs and 63in total (height+length+width).
    Any suggestions on possible problems would be appreciated.
    I'm also trying to find a rental house in the Munich area that could provide a small jib and rails for the 2 week shoot.
    Thanks in advance for any suggestions.
    Frank Weeks
    www.digitalcinemasouth.com
    Red One MX and Epic
    Senior Member Nick Gardner's Avatar
    Oct 2007
    Baltimore
    Delta is brutal, and wickedly stupid. Pint this out -
    http://www.delta.com/traveling_check...ndex.jsp#media
    Take it with you. Have a laminated card with your picture and the name of your company and the word media on it. If you are connecting in a European airport, be prepared for them to yell at you about the two carry ons. Be patient, and explain what they are. Ask at the ticket counter in the US for a tag for your carry ons. Some times they give you a first class tag to put on there so nobody bothers you.
    I would make sure to have a plan for suicide as dealing with Delta is often worse than death, and if I had had access to the sweet embrace of the Angel of Oblivion, I would have taken it many times.
    Nick
    Thanks Nick. Fortunately I have a direct flight from the US to Munich.
    BTW I brought up the Media Baggage noted on the link above to phone support at Delta.(3rd-25th checked bags 50 USD/CAD* each if under 100 lbs. (45 kg) and 115 total linear inches**) They were clueless about it an insisted that the limit was 50lbs and the cost was $200 per bag. I was sent $220 in vouchers from the producer in Germany but have not yet booked the reservation. I will continue to weigh the options. US Air is actually cheaper but the vouchers gave Delta the slight edge.
    Appears to be an accurate statement.
    Frank Weeks
    Red One MX and Epic
    Feb 2007
    Austin,TX
    Look into getting a carnet as well or you may have issues getting your gear back into the country.
    http://shanefkelly.com
    Epix-X#607
    Wise men talk because they have something to say; fools, because they have to say something.
    Plato (427 BC - 347 BC)
    as far as you are looking for rental houses - contact licht&ton and say hello to mario or thorsten
    http://www.lichtundton.tv/start/
    0049 89 856 356 33
    if you don't find what you are looking for there contact Ludwig Kamera
    http://www.rental.de/
    best wishes and kind regards,
    martin
    Member Ulf Krentz's Avatar
    Jan 2012
    Germany
    Frank, for rental you might also take a look at:
    www.fgv-rental.de
    Enjoy your time in Germany!
    Cheers, Ulf
    Thanks Shane, I'm clueless about the carnet. Is it obtained here in the US or when arriving in Germany?
    Thanks Martin and Ulf. I'll check out your suggestions. I hope they understand English as well as you guys.
    Frank Weeks
    Red One MX and Epic
    Senior Member William Albertini's Avatar
    Nov 2011
    New York, NY
    Quote Originally Posted by Frank Weeks View Post
    http://www.uscib.org/
    I have done this and it is a real pain in the ass, unless you really enjoy filling out forms. If you are worried about getting your equipment back into the States I would recommend taking all your purchase receipts, with their original US shipping address as proof that it originated here. It took me almost 2 years to get back my carnet security deposit, 20% of the value if i recall.
    Wow. That does sound like a real pain. And not cheap on an already tight budget. I'm glad you mentioned bringing the purchase receipts.
    I'm curious. Have any reduser pros had real problems getting equipment back to the US? Particularly from Germany. It's a problem I never considered and one of the reasons I started this thread. Thanks for the heads-up William.
    Frank Weeks
    Red One MX and Epic
    Member Miles Heckendorn's Avatar
    Nov 2011
    Norway
    Quote Originally Posted by Shane Kelly View Post
    +1
    I actually haven't flow into the US with large amounts of equipment, but having the correct carnet paperwork has helped out tremendously in Europe and Asia.
