Click here to go to the first RED TEAM post in this thread.   Thread: Magma ExpressBox 3T
Page 7 of 10 FirstFirst ... 345678910 LastLast
Results 61 to 70 of 93
  1. #61
    Make sure your laptop is on mains power AND has at least 50% battery...
    Testing Promise 6 bay TB with Mangma with RR...
    M
    Jun 2008
    Any updates? Curious how these would work in tandem:
    Ultra studio (for resolve)
    SAS Storage H680
    Rocket
    Promise RAID
    At what point do you begin to saturate the TB lanes?
    Meddin Studios
    Production Rentals and Services
    Post-Production Editing, Color Correction and Finishing
    Savannah, GA
    912-944-6111
    www.meddinstudios.com
    Braunschweig, Germany
    I have no problems using BM Intensity and RR in an Echo Express Pro and a Pegasus RAID on the other port of a Retina MBP.
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
    Senior Member Steve Sherrick's Avatar
    Boston
    Quote Originally Posted by Uli Plank View Post
    Uli, which Retina are you using? The maxed out version?
    Steve Sherrick
    Chief Collaborator
    Modern Vintage Media
    STEVESHERRICK.COM
    Local 600 DIT/Operator
    2.6 Ghz with 512 GB SSD and 16 GB RAM. I consider RAM more effective than clock cycles. With the Thunderbolt box and the RAID it comes quite close to a MacPro…
    One example: 1 Minute of native QuadHD 25 fps transcoded to 1080 in max quality in 19 minutes by CPU, 50 seconds by RR.
    Regards,
    Uli
    Oct 2010
    Canada
    Uli what speeds are you getting with the RR? As in 4x or ? playback res?
    Im thinking of getting the new Sonnet Temp SSD Pro to avoid external drives.
    Want to make this small as possible.
    The Red Rocket card and several other manufacturer's PCI-e cards are thunderbolt "aware", and will work over thunderbolt as long as the device was plugged in during startup as with normal PCI-e extension setups, but because the cards will never be hot swappable they cannot be classified as thunderbolt "compatible", and will only ever be listed as thunderbolt "aware".
    Oct 2010
    Canada
    Does anyone know if GPUs work with the Magma?
    Sadly the Sonnet dont.
  9. #69 GPUs and Thunderbolt Expansion boxes
    Senior Member Neil W. Smith's Avatar
    Mar 2008
    Quote Originally Posted by Eric Santiago View Post
    GPUs not working with the Sonnet expansion boxes is not specific to Sonnet or any Tbolt manufacturer for that matter .... most modern PCIe GPUs are x 16 lane PCIe cards with very high speed I/O to the MB and CPU .... Tbolt by definition is only x 8 lanes maximum ... so though you can get 10GBs I/O speed on the Tbolt bus you don't have enough PCIe lanes to carry the tremendous amount of data that modern GPUs typically process.
    Believe me, I've tried every which way to get our Sonnet Tbolt expansion boxes to work with nVIDIA GPUS ... but no luck (if anyone cracks the code - please let us all know) ... Tbolt will not even see a x 16 lane GPU.
    Also, the bandwidth requirements for CUDA based image processing are incredibly high ... in one of our Mac Resolve Systems I'm using three EVGA GTX 690 cards (i.e., six GTX 680 cards) to push Resolve to the limits .... only the PCIe bus can handle that data throughput.
    The Sonnet Tbolt expansion boxes are terrific for adding RedRocket, Fiber Channel, 10GigE and eSATA cards but alas not GPUs .... still a Retina Display MBP with a couple of Sonnet Tbolt boxes attached is a beast of a machine .... now if there was just someway to snuck a couple of EVGA 690s in there somehow, we'd be happy as Larry.
    Will be interesting to see how Apple incorporates Tbolt and USB 3 as well as PCIe 3 into next year's Mac Pro Tower upgrade.
    Neil
    Neil Smith,
    CEO
    Hollywood DI and LumaForge
    Faster Cheaper AND Better - choose all three!
    www.hollywooddi.com
    www.lumaforge.com
    LA. CA. USA
    323 850 3550
    Oct 2010
    Canada
    Thanks Neil.
    Yes that would be perfect if GPUs did work on the Sonnets :)
    I take it that the Magma isnt 16x either.
