Click here to go to the first RED TEAM post in this thread.   Thread: White Balance and the Side Handle
Results 1 to 9 of 9
  1. #1 White Balance and the Side Handle
    Senior Member steve green's Avatar
    Jan 2012
    Thousand Oaks, Ca
    Hi guys,
    A small issue I'm having when only using only the side handle. On the rare occasions I need to white balance, when I want to go back to the preset menu color temps the auto white balance values are still present. The tint is adjusted for the old white balance not reset to 000. When the touch screen is connected it's simple to hold down the color temp menu and adjust the tint back to 000, but with the Side Handle I haven't found a way to access the tint. Any ideas or workarounds?
    Junior Member
    Apr 2012
    This stumped me too for a bit. When you have the red line under the color temp menu just hit the up arrow on the side handle. That should take you to the advanced menu.
    Bob
  3.   This is the last RED TEAM post in this thread.   #3
    Starting to 3.2.x we added a "..." entry to the drop down spinners that will also open up the advanced menus. Pressing UP and holding the slot is generally faster but both are non-obvious and can only be discovered by studying the operations guide.
    Jan 2012
    Thousand Oaks, Ca
    Fantastic, can't wait to get home and check this out.....thanks so much for the help.
    Senior Member Nick Pasquariello's Avatar
    Dec 2010
    Providence, RI
    Steve, try hitting Up on every category; you'll find that about half of them, maybe more, get you to useful items that are not instantly obvious.
    Icarus Rex Productions
    Scarlet #1798 "Ariadne"
    Junior Member Aaron Haberfield's Avatar
    Nov 2011
    Newcastle / Sydney
    Really good tip. thanks Bob
    Camera OP Enigma Video.
    follow me on twitter.com/aaronhaberfield
    www.enigmavideo.net.au
    Jan 2012
    Thousand Oaks, Ca
    Thanks, Nick.....I'll be back in town tomorrow and I'm looking forward to experimenting with all the tips I've received. This Reduser site is awesome!
    Jan 2012
    Thousand Oaks, Ca
    That tip fixed me right up......"up" bottom on the side handle=advance menu.......awesome!
    Member Jose Alejandro Acosta's Avatar
    Nov 2011
    Atlanta, GA, USA
    This was very helpful! I had the same problem and assumed it was a firmware issue. Easy fix, thanks!
    Epic-X #01617 "FRANKENSTEIN"
    digital cinema / visual effects
    potfolio: http://doubleraven.smugmug.com
    IMDB: http://www.imdb.com/name/nm3425519/
