Click here to go to the first RED TEAM post in this thread.   Thread: Side handle not working??
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1 Side handle not working??
    Senior Member Justin Marx's Avatar
    Jul 2011
    Hollywood, FL
    My side handle stopped working? The screen lights up, but nothing comes up?
    I re-installed firmware (removed side handle)
    Any ideas?
    EPIC-M 1261 - officially named "Take 2"
    Senior Member Chris McKechnie's Avatar
    Mar 2011
    Orange/LA County
    Mine stopped working at one point...if you have re-seeded it, try killing all power to the cam (remove batteries too), then try reseeding, power up. See if that works...worked for me. :-)
    Chris McKechnie
    DP/Cinematographer/Editor
    web: http://digitalcinemaguy.com
    RED Epic M Package
    Canon L Series Primes/Zooms
    Steadicam, Sliders, etc.
    Nov 2007
    London
    I just had the same problem.
    What does "reseeding" it involve?
    Thanks for any info
    Nigel
  4.   Click here to go to the next RED TEAM post in this thread.
  #4
    Quote Originally Posted by nigelsmith View Post
    Thanks for any info
    Nigel
    I think he meant re-seating it. Remove the side handle from the brain and re-attach using the large thumb screw.
    Nov 2007
    London
    Doh!
    Thanks Trent, I'll try that.
    Jul 2011
    Hollywood, FL
    Will try this now!
    Jul 2011
    Hollywood, FL
    Doesn't work, any other ideas?
    Nov 2007
    London
    Mine was working again earlier - I started up the camera without the LCD attached and the s/h display worked!
    However I shut camera down to replace s/h battery and it stopped working again :(
    This has only happened since upgrading to v3.2.16
    I'm going to have to file a ticket....
    Jul 2011
    Hollywood, FL
    Anyone else having this problem??
    Senior Member Michael Totten's Avatar
    Jan 2008
    Los Angeles, CA
    Yes, I have the same problem. Side handle brand new - used once. Tested on 3 different Epic Bodies.
    These two threads should be one.
    http://reduser.net/forum/showthread....rly&highlight=
