Thread: Finally switched from Mac to PC: And this is what it looks like!!
Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 67
  1. #41
    Senior Member Asif Limbada's Avatar
    Jul 2011
    Sharjah, United Arab Emirates
    Update:
    RED Rocket and BMD Decklink has stopped being recognised, any suggestions guys.
    What are those red lights on the ROCKET for??? Cos they are on!! Should I be worrying???
    Limbada Film Production | LeverEdge Films Inc. Sharjah, United Arab Emirates | Toronto, Canada
    EPIC-M MX #964 EPIC-X MX #5432 EPIC-M Dragon #XXXX (Coming Soon)
    LEICA Summilux-C Set | COOKE S5/i | ARRI Master Prime Set | ARRI Master Zoom
    LOMO Primes | RED PRO PRIMES Set | Canon EF Set
    Jul 2011
    Quote Originally Posted by Michael Ou View Post
    Just picked up the GTX690 today and am waiting for the Xeon(s) to arrive. I'm going to start assembly with the MOBO and PSU today. Seems like you are making great progress Asif! You've met many obstacles and were able to overcome them. I'm still at the "wonder if the components work" stage." I look forward to the "making everything work together stage".
    Did you get the X9DAi with the chassis installed or did you get them separately? I may have a couple of silly "plug goes where?" questions for you.
    The agents here fixed it themselves. I never had the chance to play with the setup.
    Yeah you are at that weird stage of getting things one by one. But when they are all there and it won't "just work" is much more bad. Trust me.
    Jul 2011
    interesting tidbit, 10 SATA ports (2 SATA3 and 8 SATA2) are similarly tagged. With that I mean irrespective which port you put the SATA3 SSD, its going to detect it as SATA3 or IF you put 10 SATA3 SSD it will only detect 2 to SATA3 no way to control which one according to SuperMicro tech. Let see.
    Jul 2011
    That would be a nicer, more elegant solution to what I had in mind, I was actually thinking about cutting a large hole through the chassis to make the card shroud fit through, but I probably shouldn't. Once I make sure all the parts work, then I'll figure out the optimal arrangement, that's the fun part.
    waiting to see whats your solution... :-)
    Senior Member Michael Ou's Avatar
    Jul 2009
    NYC - Houston
    Quote Originally Posted by Asif Limbada View Post
    I wish I was a little more creative, but after a long 10 hour research session, I caved in and bought this:
    http://www.newegg.com/Product/Produc...82E16811815011
    It was on sale yesterday for only $140 without a power supply. I know, I already have the other case, that's why I'm going to build two, one for the studio, and a mobile cart based unit. Plus the double parts will go a long way to help me troubleshoot components easier, with less guessing. My original though was to configure the Super Micro case with rails for rack mounting, so I could theoretically cut away at the case to clear room for the GPU, but the thought of metal shards everywhere and making a mess did not appeal to me at the moment, but I have not ruled that out for a possible future "super mobile unit" build.
    During my troubleshooting, I discovered I also had a bad motherboard, so back it will go.
    Hope you are making good headway!
    You guys are selling a lot of Macs with this thread. I used to build PC's for Linux and some for Windows and got tired of this crap. And I am an IT Consultant. If you MUST go to Windows, buy from Dell, HP, or ProMax.
    Otherwise, offline edit or use reduced rez playback on a Mac.
    Post a link to a 5k test file and I will try it. I have Symphony 6, FCP7/X, and CS6 Production Premium, so pic your poison.
    Y'all be cool,
    Robert:-)
    Jul 2009
    NYC - Houston
    This is not much different than those Hackintosh threads, building a comp is not for everyone, and what we are building is clearly not the run-of the-mill editing workstation. These machines will hopefully be ready for 6K in the near future and perhaps a little beyond. But the learning curve is steep, time consuming and definitely not for the non-technically minded. In fact, if my editing and directing friends ever ask me if they should build one, I would advise them against it, but if they are like me, curious, like to understand the inner workings and nuts and bolts of their computers, then those guys will actually enjoy the process.
    Jul 2011
    I agree with Michael, the reason for this thread is to make sure the people if they want to go the "other" route would not have to go through the same mistakes.
    The reason for me building this machine was for RAW editing without compromise. Even with wrong choices on the way we still dont spend as much you would on the current gen Mac or HP. Until RED & HP actually release a modular system for a post production machine, I think we are going to build these kind of machines.
    Jul 2011
    Btw, Micheal, I am looking at Cooler Master Cosmos 2 rather than the Xigmatek. Its better built. What say, why didn't you get that one. Curios...
    Jul 2009
    New York
    Quote Originally Posted by Robert A. Ober View Post
    No.
    Now there's an idea. This is the kind of innovation we need on the hardware side. Hope RED and HP are listening.
Tags for this Thread
View Tag Cloud
