Click here to go to the first RED TEAM post in this thread.   Thread: EPIC / SCARLET Firmware 3.3
Page 22 of 35 FirstFirst ... 1218192021222324252632 ... LastLast
Results 211 to 220 of 344
  1. #211
    Love the absolute pixel frame guide control! Nice update guys, thanks.
    Sean Porter
    Cinematographer
    Brooklyn, NY
    Quote Originally Posted by Elizabeth Lowrey View Post
    +1 on that . I eliminated the default cycle AF mode behavior of my SH button because I found that cycle function useless without some display of what mode you are actually in. I actually wish there was some way to eek out a little bit more screen real estate somehow on the menus overlay for the LCD so that you could have continuous indication there of your AF mode.
    Worse than useless; it's possible to press that button accidentally and shift from single mode to manual (or whatever comes next) and, without knowing it, be out of AF mode entirely.
    I noticed that when you display the lens dialog (easiest way is up arrow on navigation group when in the aperture slot), the scroll wheel on the navigation group --both on the side handle and on the redmote -- do not actually change the aperture values as I assume they are meant to.
    This may not be what you're looking for; it changes the values without bringing down the menus. But if you're using the side handle to change ISO, iris, etc., the most flexible and quickest way I've found so far is to use the top four SH buttons combined with the front rotor programmed to "slot: next value" and "slot: previous value."
    These button functions and presets have gotten pretty slick.
    Senior Member Dane Henry's Avatar
    May 2009
    South Lake Tahoe, CA
    Love the update...BUT once I shut the camera down the camera will no longer start up. Fan spins LCD on Side handle lites up then camera stops/fails starting up.
    I have had to reflash the update 4 times now and the samething has happened everytime I shut the camera down for the 1st time.
    Any help/fix for this? I'd love to use this build here soon.
    Thanks a bunch,
    -Dane
    Nov 2009
    @Dane
    Will it boot up the first time after the 3.33 firmware update, but subsequent reboots don't work?
    Try this:
    under maintenance - restore factory defaults.
    Power down.
    Force upgrade to 3.33
    restore factory defaults again.
    power down
    power up.
    Senior Member Cédric Laty's Avatar
    Jun 2009
    France
    hi
    thanks but
    please, lot of us need the 4K ANA on the scarlet
    why can't it be ?
    RED ONE #1662 RED ONE MX #4496 SCARLET #355
    May 2009
    Quote Originally Posted by Dan Kanes View Post
    @Dane
    Try this:
    Power down.
    power down
    power up.
    Yep, subsequent reboots will not work. I'll give your tip a try. Thanks!
    -Dane
    Senior Member Patrick Grossien's Avatar
    Nov 2008
    Germany
    Stuart or RED TEAM:
    I had a glitch come up...
    I set a preset for the "power up" sequence and couldn't boot the camera anymore when plugged into the A/C Adapter.
    I could boot it via Sidehandle REDvolt, removed the preset and it booted nicely after that.
    SCARLET-X "Mathilda"
    "Life is full of obstacles. They never end. The ones that get past them have the richest life."
    jim jannard
    "if your pictures aren't good enough, you aren't close enough."
    robert capa
  8. #218 Camera speaker
    Quote Originally Posted by Stuart English View Post
    Sorry Ray, that's a BEEP speaker only.
    No problem Stuart, thanks.
    Nov 2009
    Quote Originally Posted by Mayo Hurajt View Post
    someone says that restart camera or unplug monitor helps. im on 3.2.16 for now which is without any stutter or issues.
    Is it possible that the SDI and HDMI are both enabled?
    I seem to remember the first time I went to that setup screen, the SDI was already enabled, but ... I could be imagining that?
    I use only HDMI. Maybe I clicked in the wrong place, and the SDI got checked by mistake?
    I'm just thinking that it must use some extra CPU to process the signal for SDI and HDMI - and that could be causing the behavior you are seeing?
    May 2009
    Quote Originally Posted by Dane Henry View Post
    -Dane
    Seems my camera wasn't liking presets I was loading from previous builds. I went though and recreated all the presets within the new build and the camera is rebooting properly.
    Thanks Dan!
    -Dane
