Click here to go to the first RED TEAM post in this thread.   Thread: Time Code Sync for 3D and Multicam
Results 1 to 7 of 7
  1. #1 Time Code Sync for 3D and Multicam
    Senior Member Pawel Achtel's Avatar
    Oct 2007
    Tasmania
    I am currently synchronising shutter of two Epics with an external Gen10 sync generator, but I don't know if it is possible to have the TC sync in such configuration.
    Is it possible to have one Epic working as a time code source and have the other Epic(s) read that time code?
    For example, connecting HD-SDI output of the Master to TC input (yellow BNC) of the Slave. Would this work?
    What are different options for synchronising TC? Currently and in future bulids.
    I think the Apendix F: 3D Setup / Operation | Connecting Cameras could be extended by giving examples of different configurations using common (compatible) "3rd party devices": Gen10, Ambient 204, Deneke SB-T, etc...
    Pawel Achtel B.Eng(Hons) M.Sc
    www.achtel.com
    Sharp to the Edge
    Land and Underwater Cinematography, Production and Equipment | DeepX - the world's only 5k underwater housing for RED Epic and Scarlet | 3Deep - the ultimate 3D underwater housing - available in US and Europe from Band Pro
    Sep 2009
    Ft. Lauderdale, FL
    I use a Deneke SB-T, factory modified to drive 2 cameras w/ a T-connector. That way, you get tri-level and timecode from the same master clock. Not sure if that's important, but it seems like a good idea to me.
    Senior Member Jason Goodman's Avatar
    Jun 2009
    New York City & Los Angeles
    Pawel,
    Not long ago, I did pretty extensive testing with the 3DSB-T, it's the best unit to use. Charlie Para of Denecke can probably tell you how to jam the SB-T to the EPIC and then the other EPIC to the SB-T if it's possible.
    Jason Goodman
    CEO
    21st Century 3D
    http://www.21c3d.com
    Jason Goodman
    CEO
    21st Century 3D
    jason@21stcentury3d.com
    @21C3D
    Dec 2009
    Chatsworthless, CA
    Contact info:
    Denecke, Inc.
    25030 West Avenue Stanford - Suite 240
    Valencia, CA 91355
    (661) 607-0206
    http://www.denecke.com
    www.cinesound.tv | location sound / post-production consultant
    Hi Pawel,
    Please feel free to send us an email (or phone call) if you have any questions regarding the SB-T. We'll be glad to help you.
    Best Regards,
    Charlie
  6.   This is the last RED TEAM post in this thread.   #6
    You can get away with 'T'ing the timecode signal to both cameras as well. that circuit is much more forgiving than the genlock input. Also if your working over short periods without rebooting the cameras, you can jam one then jam the other from the same source and they will freerun after that. but if you reboot or are on for half a day or more I suggest re-jamming.
    The PRO-IO module also has a timecode output that can be used to jam another camera in the mode you are thinking.
    Oct 2007
    Tasmania
    Fantastic! Thanks to everyone for all suggestions.
    www.achtel.com
    Sharp to the Edge
