Thread: Best baseplate for Epic??
Results 1 to 7 of 7
  1. #1 Best baseplate for Epic??
    Senior Member Jeff Barklage's Avatar
    Nov 2007
    Cincinnati, OH
    I was wondering what everyone was using for their baseplate (bridge plate) on their Epics and Scarlets?
    I have both an ARRI BP-7 and an ET baseplate (15mm).
    But both seem very LONG when the camera is bolted on....surely there is a smaller/shorter baseplate that matches the smaller size of these cameras.
    What are you guys using?
    Any advice?
    cheers,
    Jeff Barklage, s.o.c.
    www.barklage.com
    agent: TDN ARTISTS www.tdnartists.com
    online reel: http://www.interdubs.com/r/tdnartist..._Jeff_Barklage
    Vimeo Reel:*http://www.vimeo.com/user5504817
    USA based DP
    Junior Member
    Jul 2008
    Sydney, Australia
    The DSMC quick release platform pack from RED is an excellent system. Its the same footprint as an epic, is flexible in that you can change the bolt on (front/back) rod holders from 15/19mm if desired, and you can break off the camera without a screwdriver. I have mine in 19mm mode and an element technica dovetail, and its really a great system. If you need to totally remove the baseplate system, its a s fast as a traditional one piece baseplate, as you just unscrew the mounting plate from the base of the camera.
    Hi Jeff
    I asked the same question two months ago. The thread is here
    Nils J. Nesse
    www.nilsjnesse.com
    www.kompendium.as
    Epic-X in Bergen, Norway
    Nov 2007
    Cincinnati, OH
    I bought this but had to return it as the rods were centered on the lens port, not offset Arri style...and all my accessories are Arri (mattebox, follow focus, lens support, etc).
    I wish to heck they made this system in 15mm Arri offset!
    I'd buy that in a second!
    cheers,
    www.barklage.com
    USA based DP
    Nov 2007
    Cincinnati, OH
    Nils, I read your earlier thread....what was your final purchase?
    cheers,
    www.barklage.com
    USA based DP
    Despite the tragic lawsuit, you can't go wrong with x's accessories.
    Victor Lazaro - Steadicam / Camera Op
    --- www.victorlazaro.com --- @LazaroFilm ---
    Quote Originally Posted by Jeff Barklage View Post
    I actually ended up buying the least renowned of them all... Gini Rig's Hummer bridge plate. It was $199 including dovetail, so I thought WTF. I'll consider it an experiment.
    I received it today. Looks solidly built. Not sure about the locking mechanism, do I have to lock it on both sides to be secure?
    I can report back when I've given it some use, if this is a useable product. Until then, I'll recommend the more professional bridgeplates from x and Denz Präzisionsentwicklung.
    Nils J. Nesse
    www.nilsjnesse.com
    www.kompendium.as
