Originally Posted by
Jeff Kilgroe
The Mercury Accelsior PCIe card is the way to go for the fastest performance. My only reservation there would be the precious few slots in a Mac Pro and whether or not you can afford to give one up for the fast storage.
As Brian pointed out above, the built-in SATA host in the Mac Pro uses 3Gbps channels. Which is fine, you will still see fast performance from an SSD, expect about 240MB/s average for read and write from the latest models out there. So, compared to a spinning 7200rpm 1TB~2TB HDD, you're looking a 1/100th of the latency in terms of seek times and you get nearly double the read performance. Write performance varies with SSDs, but generally speaking you can expect it to be about double that of the HDD as well.
Another option is to connect one of the 6Gbps SSDs to another SAS/SATA host controller in your system. If you are running a backup system like an LTO drive, you probably have a controller like the ATTO H680. Of course, that particular card doesn't have internal connectors, but there are models that do. And these controllers are bootable. Areca, HighPoint, ATTO and others all make Mac-bootable SAS/SATA controllers, so you can add something like the ATTO H644 and gain 4 internal 6Gbps connectors as well as a 4 external 6Gbps connectors. Both with the appropriate fan-out cables. And you can boot your system from drives connected to it. Only tricky part about doing this for internal drives is mounting them. You can stack a couple in the lower optical bay and run your cables to there. Or you can use the 4 3.5" drive sleds, but you will need an adapter bracket and an extension to reach the power connector as you have to space the drive away from the onboard SATA port.
Where there's a will, there's a way...
