Thread: Epic + helicopter shooting shutter speeds & frame rates??
Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. #1 Epic + helicopter shooting shutter speeds & frame rates??
    Junior Member
    Nov 2008
    St. Margaret's Bay, Nova Scotia, Canada
    Has anyone done a lot of heli shooting with the Epic? Any recommendations on shutter speeds? frame rates?
    Kelsey W.
    Mar 2012
    ID / WA State
    i asked almost the same question, as i am going to hopefully shoot from a helicopter and its my first time... to summarize, people favored slightly over cranking and a slightly faster shutter speed, like a 90 degree shutter angle. it just gives you more options in post. def shoot 5k and a little wider than you think so you can stabilize it in post and crop in if need be.
    Michael Notar
    WWW.SHUTTERWORKSFILM.COM
    Video Production and Equipment Rentals.
    Senior Member Bryan Moore's Avatar
    May 2012
    Las Vegas, Nv
    I will let you know in 2 weeks. Ill be shooting a ton of heli footage for the first time with epic.
    Tempt Media Films
    www.temptmediafilms.com
    Senior Member JanneJansson's Avatar
    Aug 2008
    Sweden
    I have done many handheld helicopter shoots with epic and I usually shoot with short shutter time (1/500 about) so I can stabilize afterwards. Important is that the lens is not warping or distorting in the edges. Use really low kompression at least 1:6. I sometimes overcrank, but then my compression ration gets worse, so it's a trade-off. Use safty strap on camera, and remember the shoot always looks cooler in camera in the helicopter then afterwards. Make sure you have the shoot, do it twise or three times, it cost much more to re-shoot the hole day. Have penty of power and easy to get redmags. Test the camera besfore the heli takes off in case you have a problem. Have side handle with redvolt and v-lock power for safety. Shoot without door on heli, and be carful of the airstream when the heli moves fast. It can easily rip the camera from your hand, or remove a cable. Try so stay out of moving air because this causes vibration that is hard to remove aftervwards. And stay on target.. :) Don't move camera arround everywhere. Put some soft electric tape over your seat buckle so you don't accidentally fall out, but also can rip it open if you need to get out in a hurry.
    JJ
    Some people use gyros, right? My understanding is those would help with vibration and help keep things more stable?
    Senior Member Eirik Tyrihjel's Avatar
    Oslo, Norway
    Quote Originally Posted by Shaun Cammack View Post
    Definetly, but they also often more than double the cost of your shoot (depending on how long you shoot), still sometimes it is needed!
    If you plan to do only wide shots, you can probably get away without it. If you use a helicopter with a three blade rotor that is newly tracked. The really dirt cheap helicopters also vibrate like crazy. Stay away from a thing like the piston engine Robinson R44, stay with turbofan helicopters - I have had great success onboard Eurocopter 350´s without gyro stabilisation. Also when filming wide, you quite often get the rotors in frame, which is easy to overlook when you are up there.
    Higher speeds also naturally generate more winds, if you are shooting without door, or with sliding door in open position, so if great speed is not required then fly slower.
    RED EPIC-M #646, EPIC-X #250, Scarlet-X P/L #2467 "Harbor", RED ONE #476 MX "MOTHER"
    Commercials | Live | Concerts | Corporate | RED rentals
    Red Pro Primes T1.8: 18,25,35,50,85,100 (all metric), red CF zoom 18-50 T3 (imperial), Red Pro Zoom 17-50mm T2.9 (metric), Red zoom 50-150 T3 (metric) + 300mm T2.8 (imperial) + tons of accessories!
    Leica Summilux-C series on order.
    www.groovyentertainment.com/english/
    Whether you think you can or think you can't - you are right. ~Henry Ford
    Last heli shot I did were shot with the shutter at 96, it should have been at 120... motion blur should be added in post. The new warp-stabilize function in AE is great btw! No need for gyros.
    BTW: It was in an R44 and vibrated like hell, but AE and warp-stabilize saved the day.
    I've used Epic countless times with SpaceCam, Pictorvision. Gyron also has an Epic compatible gymbal.
    Best way to do your aerials.
    Mar 2011
    Hollywood CA
    The Cineron is specifically designed for the Epic/Scarlet and is perfect for handheld bungie mount out the side of a full size and is small enough to be used on a RC helicopter. It is amazing footage that does not require any post stabilization. Here is a pic of a early version last time we shot with it.
    Here is some footage shot with a early prototype https://vimeo.com/35672071
    Senior Member KETCH ROSSi's Avatar
    Jan 2007
    ITALY
    Quote Originally Posted by Aaron McLane View Post
    Great work Aaron!!
    Cost, Availability and... Can it be mounted on anything else then RC Helys?
    Like, on the Hood of a Car, hanging off an Easy rig and such or even should I dare say, HAND HELD??
    This could be perfect for "RAPEofaBEAUTY" in Rome do to some restrictions.
    KETCH ROSSi | EPIC-M DRAGON M8
    Producer | Director | DoP |
    *CinePhotographer
    __________________________________________________
    *Registered Trademark of RED DIGITAL CINEMA
