Thread: Power management update?
Results 1 to 9 of 9
  1. #1 Power management update?
    Senior Member Patrik Kisucky's Avatar
    Sep 2010
    Boston, Ma
    Is there any news on the power management improvement? The last time I read about it, was about a month ago, when Jarred mentioned, the improvements would be in small increments instead of a big jump. Did anyone hear anything else since then? Anyone? (RED Team?)
    Thanks. Can't wait to see if we could bump up the Redvolt time to 40ies:)
    Scarlet-X, #899, "Precious"
    ParadigmsPictures.com
    VideographerforWedding.com
    Senior Member Trevor Meeks's Avatar
    Jun 2009
    Sonoma, CA
    If it had happened, I think we all would have heard about it ;)
    Hang tight... they've got their hands full and I'm sure this is on the list.
    Sep 2010
    Boston, Ma
    Yeah I know, would be great to know how far they are.
    Senior Member Jon Carr's Avatar
    Aug 2009
    NYC
    Power management update.....
    Buy at least 3-4 bricks and your good.
    Dp Reel
    http://www.visualcinema.com/reels/
    Rentals in NYC
    http://www.visualcinema.com/rentals/cameras/
    EPIC-X #____ (soon to be Dragon)
    Canon & PL mount, Canon 16-35, 24-70, 70-200, Rokinon 24mm, 35mm, 85mm, & everything you need to shoot RED!
    It's REDcode or no code...
    Oct 2009
    Dresden, Germany
    Last info was: power management will be integrated in little pieces step by step. Don't expect a huge improvement in something like a build dedicated to power management
    Scarlet-X #1388
    Canon 24/1.4IIL 50/1.2L 85/1.2IIL 24-105/4.0L | Sigma 35/1.4A
    Senior Member Nick Pasquariello's Avatar
    Dec 2010
    Providence, RI
    Keep in mind how software development works: the features we're seeing now are things that they probably started working on 3 months ago or more. In some cases, MUCH more. A feature has to be designed, coded, and then tested tested tested to make sure it doesn't break anything else.
    So, even if Jarred had come out and said "Ok, Power management is now our TOP PRIORITY" I wouldn't expect to have it in my hands until 2-4 months later.
    Icarus Rex Productions
    Scarlet #1798 "Ariadne"
    Sep 2010
    Boston, Ma
    Thanks Nick, that makes sense.
    Nov 2009
    Power management is very tricky - and can cause hard to diagnose problems if there are software bugs.
    Instead of pressing RED to hurry up, I'd rather they took all the time they need, and have an option to turn it off.
    Yes, it would be nice to have but ... I guess my focus is just on stability, making everything rock-solid ... and compatibility with more lenses, so that any Canon compatible lens will work (although, maybe not as fast as one that's programmed to work).
    My XMAS list of features for this year has already come quite early from RED.
    Jun 2009
    Sonoma, CA
    Agreed, Les!!!
