Click here to go to the first RED TEAM post in this thread.   Thread: Mountain Lion: Any Issues?
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
  1. #11
    Senior Member Jeffrey T. Morgan's Avatar
    Oct 2007
    Michigan
    It was tough installing the newest Cuda software and the Red Epic Importer for CS5.5 until I found this:
    http://www.computeraudiophile.com/f1...elopers-12789/
    Now I have the gt 650m hacked in for MPE and it's all looking FAST!
    MacBook Pro, 2.7ghz i7, 16gb ram, Retina
    Jeffrey T. Morgan
    Producer • Director • Cinematographer (Local 600) • Editor
    www.PrometheusMotionPictures.com . . . Twitter: (at) JeffreyTMorgan
    SCARLET-X #1633 "The Dark Knight", Now booking Michigan and Worldwide
    Canon and PL Mount, 5" Touch LCD, RedRock FF and Mattebox, Cartoni Delta Head, Contax Zeiss lenses and much more
    Senior Member Mike 'Fireman' Ross's Avatar
    Jan 2011
    Wellington New Zealand
    10.8?
    Brave people.
    Put it this way; I consider 10.7 is now well-enough tested and well-enough understood, and am considering upgrading my main production machine to it.
    Unless there's a compelling reason, be the last to upgrade, not the first!
    Mike
    'No greater love hath a man than he lay down his life for his brother.
    Not for millions, not for glory, not for fame.
    For one person, in the dark, where no one will ever know or see.'
    RED SCARLET-X #513, 'Hekla'
    RED EPIC-X #2229, 'Katla'
    RED ONE MX #10066, 'Askja'
    Senior Member Jake Bastian's Avatar
    Feb 2008
    SLC, UT
    early 2012 Macbook Air, crashing every time it's closed and reopened. I guess you could call that a sleep issue.
    Jun 2009
    Los Angeles, CA, USA, Earth, Solar System, Milky Way
    I have a Retina MBP and haven't had a single issue with any software I run (Adobe, Avid, FCP7, FCPX, Resolve, RCXP, R3D Data Manager, etc.). Make sure you have the latest drivers and versions for everything. And Mountain Lion has been noticeably/much faster than Lion. Very impressed.
    Senior Member andrewhake's Avatar
    Oct 2009
    People really can stop being so paranoid about upgrades with them coming out much more often. Small problems get fixed way more often, and the actual upgrade process gets more and more streamlined.
    That said, if it is a work machine and you have some free time, it is simple enough to clone your current system drive to another one, do a direct upgrade on the clone, and see how things go. This is even easier as many people are using a Mac Pro with easily replaceable drives. It is always a good idea to do a full clean install and reinstall all of your apps/tools/preferences but with 10.8 a direct upgrade (normal App Store install and upgrade) I have had zero issues amazingly. The variety of applications and tools I use would boggle many people's minds, and somehow it all works correctly, and in many cases works much better.
    If you are still on 10.6 I would definitely suggest to just skip Lion all together. Not because I had any major issues with Lion (for many things it was better for me than 10.6), but because 10.8 is fantastic.
    It seems that many start-up apps are causing occasional "black screen of death" system hangs after log on with Mountain Lion. I've confirmed that RED Watchdog will occasionally trigger this issue. The problem is wide-spread and lots of apps are triggering the issue. Several work-arounds exist at the moment, like auto-login or loading the problem apps after log-in.
    - Jeff Kilgroe
  7.   This is the last RED TEAM post in this thread.   #17
    Jeff: it at least installed fine on an early 2009 Mac Pro I have sitting here ;)
    We've been testing with REDCINE-X PRO on Mountain Lion for a while now and things seem fine. We've not seen the Mountain Lion black startup issue yet internally. For people who've missed it, the latest RCX PRO beta also supports the new retine macbook.
    Rob
    ROBCODE Santa Claus @ RED
    "You get the chicken by waiting for the egg to hatch, not by smashing it with a hammer" - Jarred
    Rob,
    As I've dug into the black screen issue more, it looks like it affects the 2012 Macbook Pro and the 2010 Macbook Pro the most. With Mountain Lion officially available for a week now a lot of the theories seem to be solidifying on an issue with graphics switching in the GDI with the discrete GPU involved is an nVidia chip. At any rate, the problem looks to be entirely an Apple issue. Many applications are triggering it. I'm not even sure if this thread is warranted because I've been able to trigger it on my Macbook Pro retina by loading just about any resident app on start-up -- RED Watchdog, Growl, etc..
    I'm expecting a fix from Apple by monday. ;) If not, they're really dropping the ball on this one.
    BTW, loving RC-X 16's retina support!!!
    - Jeff Kilgroe
    Oct 2010
    New York, NY
    Watchdog and Growl are fine on startup and beyond on this end on Retina + TB monitor. Sorry you're having a bad go of it, I've had smooth sailing so far on ML, all programs seem to run just fine.
    -Drew
    andersonDboyd@yahoo.com
    http://www.imdb.com/name/nm2326768/
    SCARLET-X #840
    FCP 7 & X - AVID MC 6 - Premiere CS5 - DaVinci Resolve 8 - RedCineX Pro
    Jun 2009
    I have not had this black screen issue at all with any apps on my rMBP with Mountain Lion installed. I tried it on both of the rMBP I've had so far.
