Click here to go to the first RED TEAM post in this thread.   Thread: Premiere CS6 and REDCINE X
Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. #1 Premiere CS6 and REDCINE X
    Oct 2010
    New York, NY
    Hi all,
    Could someone chime in on the best workflow for roundtripping between Premiere and RedCine-X? I've come to really like grading in RedCine-X and have chosen it as the grading platform on my current job. However, roundtripping between Premiere is proving to be a problem.
    After sending to RedCine via either XML or EDL all is well, I grade, then try and send back to Premiere. I either get a sequence that shows the clips but the viewer shows nothing but black, or I get an empty sequence. I'd do the conform in RedCine X if only it supported various speed/post effects like warp stabilizer, but it understandably doesn't, so I have to finish in Premiere.
    What's the route to success when alternating between PP and RedCine-X?
    Thanks in advance,
    Drew
    -Drew
    andersonDboyd@yahoo.com
    http://www.imdb.com/name/nm2326768/
    SCARLET-X #840
    FCP 7 & X - AVID MC 6 - Premiere CS5 - DaVinci Resolve 8 - RedCineX Pro
    are your clips at 100% size? might be a small bug, so you would only need to adjust the size of a clip and copy it to the others.
    Scarlet-X #947
    Designguide.tv
  3.   Click here to go to the next RED TEAM post in this thread.
  #3
    Red Team
    Sep 2009
    Irvine, CA
    I've fixed that problem for the next release.
    David
    Oct 2010
    New York, NY
    You guys are on top of everything, many thanks!
    -Drew
    SCARLET-X #840
    Member Angelo Lorenzo's Avatar
    Jun 2012
    Los Angeles, CA
    For now, you can select all the clips in your timeline (ctrl+a), in the menu go to Clip > Remove Effects and remove any motion effects. This should reset the clips to 100% scale.
    Angelo Lorenzo
    Fallen Empire Digital Production Services - Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire - The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Senior Member Kaku Ito's Avatar
    Feb 2008
    Chiyoda-ku, tokyo
    That's great David.
    Another ways of adopting the color grading in REDCINE-X Pro is that you choose the preference to save the RMD, do the color grading, just go back to your original Premiere Project then the R3D clips on your premiere timeline would conflict the RMD that REDCINE-X Pro has saved automatically (unless you have saved custom RMDs in Premiere Pro before you have sent the XML to the RCX Pro).
    Kaku Ito
    rawesome! Equipments
    RED Epic-M, RED Epic-x, RED ONE MX x2, RED ONE Mysterium, Allstar A-mount, Epic Canon Ti Mount, 1.8' SSD modules, RED PRO Prime Set (18 through 100mm), various Nikon and Zeiss Lenses, 17-55mm RED Pro Zoom, 18-85mm RED Pro Zoom, x2 RED ROCKET, Mobile Rocket, DaVinci Resolve, Cubix, GTX-285, Quadro 4000, few Mac Pros, few MacBook Pros, Sony BVM-D24, Panasonic 65 inch Series 12 plasma, Calman with Klein probe.
    Rawesome! One Stop RAW Visual Production Service
    Feb 2008
    Chiyoda-ku, tokyo
    When would that be released, David?
    Kaku Ito
    Senior Member Cory Petkovsek's Avatar
    Sep 2010
    San Diego
    I can vouch for David working diligently on FCP/PPro/RCX importing and exporting. In general, don't ask developers for dates; they won't be accurate. However you don't need the next build to do it. It isn't ready for round tripping anyway. What it is ready for is to meet your needs.
    In PPro, export your project either as an EDL or fcpxml.
    In RCX, import to a timeline, or bin or both, whichever works for you.
    Grade and save the RMDs.
    Use the handy utility that was just released by Angelo to tell PPro to reload all the RMDs:
    http://www.reduser.net/forum/showthr...e-Premiere-Pro
    Cory
    Cory Petkovsek
    Corporate Video
    Oct 2010
    New York, NY
    Unfortunately that program doesn't work, at least for Mac.
    It's a handy idea, but has limited potential. In many instances footage cut from the same R3D will be graded quite differently, so a universally applied grade doesn't help too much.
    Roundtripping a timeline where the graded metadata is maintained for each instance of an R3D would be the best case scenario, I'll gladly wait for the next RedCine-X if this is a possibility.
    -Drew
    SCARLET-X #840
    Senior Member Ryan Sauve's Avatar
    Oct 2011
    Calgary, AB
    I just want to double-check that I'm not missing something, Alchemy Group color grading changes (alchemy, clarity, skin) made in RCX don't get propagated to PP CS6 right? It looks like pretty much everything else does, except for maybe film grain?
    Ryan Sauvé
    A Guy with a Camera | i4Life Studios | Epic-X #5343
