Click here to go to the first RED TEAM post in this thread.   Thread: Redcine Audio Distortion
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 Redcine Audio Distortion
    Junior Member
    Jul 2012
    I'm using Red footage for the first time (and am ecstatic) and learning about Redcine-X Pro. All has been going well until I tried to sync the audio in the program. I followed the tutorial and everything appears like it worked well (it went out and found the correct audio files for the scenes), but when playing the clip, the audio is heavily distorted and screeching. It almost sounds like it's playing the sound 10x louder than it should, so it just becomes a distorted mess of screeching and rumbles. The wav files, when opened in a different program, sound great.
    Any tips, help or information on why or how Redcine is screwing with audio?
    Thanks so much!
    Junior Member
    Jul 2012
    I've tried it on a few computers, so I know it's not an issue with the computer. Not sure what else to try at this point!
    Senior Member Terry VerHaar's Avatar
    Sep 2009
    Silicon Valley, CA
    Just a thought - are you sure the audio was recorded correctly? Is it possible you recorded it too hot and you are hearing the digital distortion?
    Junior Member
    Jul 2012
    I can go listen to the audio in another program and it sounds fine. Plus the audio guys are top knotch... Grimm's audio guys.
    Senior Member Shawn Nelson's Avatar
    Portland, OR
    Chris needs some help, I'm surprised no one from Red has chimed in, is there an email of someone in Red who would help him troubleshoot this?
    "Only those who attempt the absurd will achieve the impossible." -MC Escher
  6.   Click here to go to the next RED TEAM post in this thread.
  #6
    Red Team
    Sep 2009
    Irvine, CA
    Hi Chris,
    Mac or Windows? How does the audio sound after transcoding through to a QuickTime? If you want to make available to me one of your files email redcinex at red.
    Thanks,
    David
    Junior Member
    Jul 2012
    Thanks for responding David. I'm using Windows. I'm transcoding a file to a quicktime now to test it. I've manually synced clips and audio in Premiere and the audio sounds fantastic that way. I'll try to get a clip and it's audio your way. Thanks!
  #8
    Red Team
    Sep 2009
    Irvine, CA
    Hi Chris,
    Also give build 15 a whirl. It's up now on red.com (or auto update). I did fix an issue that sounds similar to yours.
    Thanks,
    David
    Junior Member
    Jul 2012
    Awesome, I'll give that a try after the transcoding.
    Junior Member
    Jul 2012
    Build 15 seems to have fixed the issue! Thanks so much for the help!
