Click here to go to the first RED TEAM post in this thread.   Thread: Tascam HD-P2 and REDCINE X PRO
Results 1 to 7 of 7
  1. #1 Tascam HD-P2 and REDCINE X PRO
    Junior Member
    Jul 2012
    Just wondering if anyone is using the Tascam HD-P2 for audio and what workflow they use.
    When attempting to link to clips in RCX Pro the audio and video link up, but there is no waveform on the audio clip, resulting in no sound. I have tried syncing manually, but still no waveform shows up.
    The audio clip plays in every other program I have tried it in though, so it doesn't seem to be a problem with the audio.
    Any help would be appreciated.
    Thanks--
    Junior Member
    Jul 2012
    bump
    Senior Member Domenic Barbero's Avatar
    Nov 2011
    Seattle/Bellingham WA
    Im curious too, since i may be purchasing an HD P2. Ps. Alex do you like yours?
    www.domenicthedp.sqsp.com
    DP/Director/Producer
    Epic-X Dragon 2756 "Krang"
    Contax Zeiss 25,35,50,85,100,180 superspeeds
    tokina 11-16
    canon 70-200
    "I don't know where the artificial stops and the real begins" Andy Warhol
    Junior Member
    Jul 2012
    It's a decent recorder. Good for the price and is easy to use. Just having problems with syncing in RCX.
  5.   This is the last RED TEAM post in this thread.   #5
    Red Team
    Sep 2009
    Irvine, CA
    Assuming it's producing a standard BWF wave file there shouldn't be a problem. Can you make available to me one of your files and I can take a look? redcinex at red dot com.
    Thanks,
    David
    Junior Member
    Feb 2008
    I had the same issue. On a lark, I ren the wav files through quicktime, telling them to export as wavs with the standard setting. Those newly encoded wavs registered just fine. I haven't been able to troubleshoot exactly what changed between the files, but my guess is there's some piece of metadata that's either missing or giving the wrong info.
    Junior Member
    Jul 2012
    And timecode matches after the export from Quicktime?
Tags for this Thread
View Tag Cloud
