Thread: Speedgrade & graphics card
Results 1 to 6 of 6
  1. #1 Speedgrade & graphics card
    May 2007
    Hi all!
    Which graphics card are you guys using with Speedgrade? Im interested to know the performance difference between the 4xx, 5xx, 6xx & Quadro series.
    Anyone using dual graphics? Any performance difference?
    Scarlet-X #2439
    Dec 2011
    I use the Quadro 4000, 4800, 5000 with SG and PR Pro with similar results.
    Personally, unless you need SDI, the 6000 may be more than you need.
    Wes
    I use the Quadro 4000 and GTX 570. I like more the Quadro card, I think its performance is superior.
    May 2007
    Quote Originally Posted by Manuel López Pérez View Post
    When you say the performance of the Quadro card is superior, do you mean in terms of real-time playback with effects applied?
    Are there certain tasks in which the Quadro cards perform better than GTX cards in Speedgrade?
    Scarlet-X #2439
    Quote Originally Posted by Zul, Y View Post
    When you say the performance of the Quadro card is superior, do you mean in terms of real-time playback with effects applied??
    Yes, that is.
    Although that is subjective, only the experience of work with both.
    Senior Member Alexander Mejia's Avatar
    Jun 2008
    Champaign, IL
    I'm running a Geforce 680 2GB on Windows 7 x64. I'm able to get real time playback after the files are cached into memory (The green bar across the top) on a 1920x1080 DPX workflow.
    I'm currently asking on the Adobe Forums if there is a way to get the initial read to play back in real time. Not sure if this is a Disk IO issue, or a gimped Nvidia driver issue.
    Alexander Mejia, Video Editor, Colorist, and Compressionist Volition-Inc/THQ-Inc. @Alexander_Mejia
