Thread: Can you Dolly in/out with sliders..???
Results 1 to 4 of 4
  1. #1 Can you Dolly in/out with sliders..???
    Jan 2010
    Wondering if you can do a slow dolly in or out with
    some of the 3-5ft. sliders out there w/o seeing the rails.
    Is at all possible with 50mm and under lenses ?
    And would elevating the camera above the slider
    with a small high hat device help much.
    Senior Member Liam Hall's Avatar
    Nov 2007
    London/Worldwide
    Yes, of course you can. And yes, a hi-hat helps. And yes, it is possible with 50mm and under.
    I make stuff.
    www.liamhall.net
    Hey Steve, It depends on the angle of your camerahead. If youre slightly below the eyeline and tilted up a fraction it should work with a 50mm and i even think with 35mm. Elevating the camera would help you additionally, but then you should consider a small bazooka which lifts the camera up. If you have a robust slider i would consider using a long camerabaseplate and a counterweight. then you can slide th baseposition 1ft forward. That should make the shot even easier possible. all best!
    Senior Member PatrickFaith's Avatar
    Nov 2011
    Northern California
    Quote Originally Posted by Steve Das View Post
    I do a lot of that with a pan/tilt head on top the slider (camera is about 2 feet off of the slider) with a 18mm RPP ... with that with a slight angle up. I also reverse the system flipping it over and have the camera "hanging" down ... so i'm looking downish with the slider being around above 8 feet high off the ground ... for overhead dolly shots when i need to see the floor. "Timescapes" has a ton of good examples using the smaller dolly stuff. you can also have the slider on a slight angle to (i.e. it isn't flat to the ground) ... if you need a straight on shot (kessler has some new "joints" to do this which are really nice).
    http://www.youtube.com/patrickfaithart & http://Pudl.tv
    "Litl" #250 "Pudl" #397 of "Ink" (Monochrome) #3752
