Thread: Premiere CS6 anything but smooth (6.0.1 made it worse!)
Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 55
  1. #41
    Found an 18-second long 5120x2160/23.976 clip and dropped it into Premiere, RR enabled... and the clip played very smoothly in both Source and Program monitors at 1/4 and 1/2 resolutions. This supports Wes' recent discovery.
    I then exported the clip to DVD-compliant NTSC MPEG-2 (2-pass encode). The process took less than 15 seconds, i.e. faster than realtime (yay!). During export there wasn't much happening in the CPU (2-5% load only, most cores active) but at least the CPU was doing something throughout the export instead of only once in a long while. The main GPU (GTX580) worked at 4%, while the GUI GPU (GTX460) stayed at 0%.
    Next test: export to Blu-ray compliant H.264 (2-pass encode at medium bitrate preset). For this test I slapped a Colorista II correction on the clip and added simple film dissolves on both ends. Export took 19 seconds. CPU usage leapt to 60-70% (all cores workout) and main GPU to 35%.
    Dec 2011
    That's one nice thing about the Rocket. It leaves your CPU available for processing things like 3rd party / Non-CUDA effects, etc.
    Senior Member Johnny Friday's Avatar
    Feb 2007
    La Paz, Baja Ca. Sur, Mexico
    Quote Originally Posted by Petri Teittinen View Post
    What was Wes's discovery? i missed that.....something about 16x9 material?
    John Friday
    La Paz, B.C.S., Mexico
    www.bajaproductions.com
    EPIC M & 2X for 3d & Deep Epic Underwater Housing
    RED MX with SSD & Underwater Housing
    Quote Originally Posted by Johnny Friday View Post
    Yes. Premiere and RED Rocket stop talking to each other when Premiere is trying to process 16x9 material, such as 4800x2700 or 2880x1620.
    The limited testing I've managed to do so far suggests this issue applies to editing (i.e. playback smoothness) and exporting alike. So if we're lucky, Adobe might squash both these bugs in one go. Fingers crossed.
    I am seeing the same issue with 16x9 Epic material. Any work arounds yet?
    Kenny Mosher
    Filmmaker, Photographer
    Showdown Visual
    www.showdownvisual.com
    Feb 2007
    So would working with 2:1 material BUT then putting it on a 16:9 timeline with center crop create these problems ?
    OR
    Is it only working with the original content at 16:9 that is the problem?
    thanks....
    John Friday
    I haven't seen the issue when cropping from 2:1 to 16:9 but only with 5k 5HD native footage. I am just disabling my rocket for this particular project. Unfortunately I normally shoot at 2:1 but this current job I shot it at 5K HD. This was before I knew of this issue...
    Kenny Mosher
    Showdown Visual
    Feb 2007
    Quote Originally Posted by Kenny Mosher View Post
    For this reason i've been shooting everything at 2:1 or 5kFF and then doing center crops from RCX...BUT, i've not yet tried any work on PrPro to see if any problems.
    John Friday
    Senior Member Peter Chang's Avatar
    Dec 2009
    San Francisco
    Are these bugs still active? Can you confirm that this issue applies to both playback and exporting?
    Peter Chang
    Director, Producer, Cinematographer, Stereographer
    Golden Gate 3D
    www.gg3d.com
    Twitter: @peterhchang | @GoldenGate3D
    Senior Member Tehben Dean's Avatar
    May 2009
    Alaska
    I really hope Adobe will fix this soon, it's really annoying. I'm glad I finally figured out what it is though :/
    TEHBEN DEAN - stills & motion
    EPIC-X #557
    www.tehbendean.com
    I love to shoot beautiful things with cameras...
