Click here to go to the first RED TEAM post in this thread.   Thread: Redcine-X Transcode error w/ RedRocket Card
Results 1 to 5 of 5
  1. #1 Redcine-X Transcode error w/ RedRocket Card
    Sep 2007
    West Los Angeles
    Putting some scarlet footage through the system. About 50% of all clips give us a "finished with error" in the status column, and when they do error out it reads "Error processing image for frame: xxx"
    When we re-run the problem clips sometimes they will finish just fine, or they will error again, but never on the same frame, which leads me to believe the footage and data files are not corrupted.
    The log for the problem files always ends with this one troubling statement: "shamem: interprocess_exception No such file or directoryredexport: failed to open shared memory object."
    Not sure what that means. We've tried different destination directories etc... always the same problem.
    Also, footage plays back fine in rcx. But these errors are making are batch transcodes take ages and it is super frustrating.
    Any thoughts are appreciated.
    - Travis MacRitchie - Epic, Scarlet, Sony F55, F3, C-300 - Optimo DP Rouge 16-42, 30-80mm, Fujinon Cabrio 19-90mm, Arri Ultra Primes, Zeiss Compact Primes, Red Pro Primes and Zooms
    BrainBoxCameras.com
    310-773-4823
    HD and RED Camera Rentals / Director of Photography
  2.   This is the last RED TEAM post in this thread.   #2
    Red Team
    Sep 2009
    Irvine, CA
    Sounds like you are possibly running out of memory. Can you enable verbose logging and recreate the the issue. Then do a save report from the help menu and email the zip to redcinex at red? I'll be able to take a closer look that way.
    Thanks,
    David
    Sep 2007
    West Los Angeles
    Just wanted to let the forum know we finally solved this issue... I used activity monitor to close all unnecessary background applications, and made sure to keep redcine as the only thing running, and that seemed to do the trick. We had some network utilities, growl, and some other stuff that might have been hogging up memory. So if you are getting weird erros, give it a shot.
    BrainBoxCameras.com
    310-773-4823
    Senior Member Tom.Wong's Avatar
    Jul 2009
    New York/New Jersey
    add as much ram as you can. helps a ton
    Local 600 IATSE Digital Imaging Technician
    Phantom Certified Technician
    Da Vinci Resolve Colorist
    Scratch Lab Operator
    https://vimeo.com/41679679
    Senior Member Timur Civan's Avatar
    Jan 2007
    New York City
    Quote Originally Posted by Tom.Wong View Post
    +1 Tom helped me set up my rocket system. 16 gigs ram, did the trick, and sped it up significantly. 4khd renders nearly double real time to proreshq.
    Director Of Photography
    RED Epic M - Fujinon Cabrio 19-90 T2.9 - Oconnor 2060 + accesories
    www.TstopCinema.com
    Timurcivan@gmail.com
    9175894424
