Thread: What wants Davinci? GPU is being used for image processing?
Results 1 to 7 of 7
  1. #1 What wants Davinci? GPU is being used for image processing?
    Could please tell me what does it mean? What this Davinci wants?
    It is clearly about not enough memory just need to install additional RAM but what she wants from GPU?
    Senior Member Ivan Kovax's Avatar
    Nov 2009
    Tokyo, Japan
    Davinci works best with TWO video cards. Please read the whitesheet on their webset in regards to optimal configurations. THe first message seems to indicate you need more memory How much memory do you have?
    Member jochem bakker's Avatar
    Oct 2011
    Netherlands/Malta
    First off, it would be helpful if you state the specs of your system. It looks to me that the first message is about your system memory. The second one states that it works best if your system uses a GPU card for your GUI and a separate dedicated GPU for image processing (without anything plugged in) for full potential of the software. It will still work in your case, but it indicates you don't have max performance. I don't think the two messages relate to one-another.
    to compare for example, i am running the GUI from my first PCI express slot (16x) with a NVIDIA GTS 450 2gb, then a dedicated NVIDIA GTX670 4GB in the 4th slot (16x), running on 32GB system RAM with enough PCI lanes on a 2011 motherboard.
    Cinematographer for Imaazje! filmprodukties
    www.imaazje.com IMDB page twitter
    I have 8 Gb memory I will install additionally 8 Gb so it is not a big problem. But videocard...Yes 580 is cerificated card but 680 has 1500 core and 4 Gb and more new then 580 so I think 680 can be use as 580 only as single videocard.
    Intell Core I7
    GTX 680 4 Gb
    Senior Member Kevin Marshall's Avatar
    Jul 2009
    Frederick, MD
    Essentially you need a second graphics card. One card does image processing, while the other handles the program interface. This can be a less powerful card - I use a GT 440, though BMD recommends a Quadro 600 or 4000, the latter being recommended for 3D work.
    Apr 2009
    Singapore
    Actually with Resolve v9, you can now use just one shared GPU for both GUI and image processing. If you plan to do this, make it the fastest GPU your system can use. The 680 you have is appropiate. Make sure you have the correct CUDA driver. Note, using separate GUI and processing GPUs will be significantly faster.
    In this specific case, are you using Resolve v9 beta 2?
    Peter
    Aug 2010
    Quote Originally Posted by Peter Chamberlain View Post
    Peter
    When using a single GPU, remember to use the "Use optimized display mode during playback" in the video monitoring section of Project Settings.
