Thread: Highest usable ISO on RED Scarlet
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1 Highest usable ISO on RED Scarlet
    Junior Member
    Oct 2009
    I was talking to a friend who has the Scarlet and I know it mainly comes down to personal preference, but whats the absolute highest usable ISO setting?
    I've gotten barely usable shots at 1250 on a Canon 7D type body camera.
    Does anyone have any test footage graded, ungraded, denoised, downscaled to 2k etc...?
    Senior Member Zac C's Avatar
    Salt Lake City, UT/Cape Cod, MA
    I don't go above 1250 unless I'm prepared to de-noise in post.
    That's my personal limit.
    Scarlet-X "Starbuck"
    Senior Member Nick Gardner's Avatar
    Oct 2007
    Baltimore
    I know it's epic, but I don't don't mind pushing it a stop to 1600. I used to try and avoid anything over 1280, but I did a months shoot with a c300 and sort of forgot and shot a bunch of stuff at 1600 and it looked great. That doesn't mean you can shot at 1600 and underexpose and get decent results. Light it right and make it look good and it will be fine.
    Nick
    Senior Member Jon Carr's Avatar
    Aug 2009
    NYC
    I like shooting at 1280, noise starts getting noticeable at 1600.
    Dp Reel
    http://www.visualcinema.com/reels/
    Rentals in NYC
    http://www.visualcinema.com/rentals/cameras/
    EPIC-X #____ (soon to be Dragon)
    Canon & PL mount, Canon 16-35, 24-70, 70-200, Rokinon 24mm, 35mm, 85mm, & everything you need to shoot RED!
    It's REDcode or no code...
    Feb 2008
    SoCal Camarillo / LA baby
    There is no set number.
    The acceptance varies from person to person, dp to dp, VFX guy to VFX guy.
    I have seen ISO 2000 be plenty acceptable, and even give the image a pleasing texture.
    I have used ISO 2500 before and been fine with it. I can see someone using 3200 in certain situations.
    There have also been times where ISO 1250 was not working for the image.
    So it can change on a per shot basis.
    In doors, out doors, Daylight , Tungsten so on and so on.
    Your very best bet is to test, try, view and test again to see how you feel about it.
    Luis
    Luis Flores Jr - DIT / Dailies Colorist - Jerusalem IMAX 3D
    EPIC-M Cameras #202 , #960, #1046, #1031
    EPIC-X Camera #300
    GOOGULPLX@aol.com
    (805) 822-9870 cell
    Senior Member Terry VerHaar's Avatar
    Sep 2009
    Silicon Valley, CA
    In this excellent article about exposure, from the RED web site, they state they following:
    "For most scenes and uses, exposing with an ISO of 640-2000 strikes the best balance between highlight protection and low image noise. If one ventures outside this range, exposure needs to be much more precisely controlled, and has much less margin for error."
    Here's the article in full:
    http://www.red.com/learn/red-101/exp...th-red-cameras
    Senior Member Timur Civan's Avatar
    Jan 2007
    New York City
    This is 2500 ISO. on epic, but literally the same thing.
    NSFW
    https://vimeo.com/47637933
    Director Of Photography
    RED Epic M - Fujinon Cabrio 19-90 T2.9 - Oconnor 2060 + accesories
    www.TstopCinema.com
    Timurcivan@gmail.com
    9175894424
    From my Scarlet #316 Skully thread:
    http://www.reduser.net/forum/showthr...l=1#post909373
    phfx.com IMDB
    Scarlet-X #316 "Skully"
    Dec 2010
    Toronto
    I find that you can push the ISO fairly high if your image isn't massively underexposed before the ISO boost. So, for example, if your shadow goalpost is registering only a 1/4 of the way up, I find that you can push the ISO up to 2000 and still get acceptable results. That said, if you're shadow goalpost is 3/4 full, boosting the ISO to even 1280 will be too noisy (it basically just amplifies the noise in the massively under exposed areas). Makes sense too.
    A few weeks ago I did a naturally lit night-time bonfire test shot while the full moon was out. What I found was the amount of light being thrown on the background landscape by the moon was just enough to keep the shadow noise at bay and I could really push the ISO without it killing my image. I pushed it to ISO2500 and it was perceptibly cleaner than "more underexposed" stuff I've shot that only needed ISO1600. If I had recorded to an SDI/HDMI off board recorder, I would be comfortable going to ISO3200.
    Jan 2007
    New York City
    The trick is to put just a little light in the frame. Just to give the sensor something to react to.
    www.TstopCinema.com
    9175894424
