Thread: Highest usable ISO on RED Scarlet
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Norway
    Quote Originally Posted by Timur Civan View Post
    The trick is to put just a little light in the frame. Just to give the sensor something to react to.
    Yup...
    The tricjk is a bit of contrast, even in low light...
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Senior Member Noel R.'s Avatar
    Sep 2011
    North Bay, CA
    Seems to work fine at higher ISO's with lighter skin subjects, but I have a really hard time with dark skin subjects and higher ISO's. The noise really seems apparent then.
    Feb 2010
    Helsinki, Finland
    The noise also depends on color temperature. With daylight you get more signal in the blue channel and can go to higher ISOs than with tungsten.
    Senior Member Timur Civan's Avatar
    Jan 2007
    New York City
    Quote Originally Posted by Noel R. View Post
    Absolutely. In the example i posted earlier, i had her use practically white makeup. It really helps in low light.
    Director Of Photography
    RED Epic M - Fujinon Cabrio 19-90 T2.9 - Oconnor 2060 + accesories
    www.TstopCinema.com
    Timurcivan@gmail.com
    9175894424
    Sep 2011
    North Bay, CA
    Good to know that's a very useful tip.
    800. ;)
    Gavin Greenwalt || im.thatoneguy
    im.thatoneguy[at]gmail.com | Straightface Studios | VFX & Animation
    Canon Scarlet-X package available to rent in Seattle, WA
    Senior Member Cid J Salcido Uyarra's Avatar
    Jun 2009
    800
    I usually stick to 320 or 640
    I have worked with old school DP who treat it like film never really trust the monitor but a meter and he used 250 EXT and 500 INT all amazing results
    Sep 2011
    North Bay, CA
    320 looks cleaner. 800 if you want to protect the highlights. 800 pretty much forces you to stop down a bit in bright light situations which keeps you from clipping RAW data, but seems to have a little more noise, still clean, but not as clean as 320.
    Jan 2007
    New York City
    Keeping it at 320 also means you are allocating far more of the exposure range to the shadow half of the frame. At 800, it means you are seeing your grey point lower, and making the exposure above and below grey equal.
    www.TstopCinema.com
    9175894424
    Member Dennis Hingsberg's Avatar
    Jan 2011
    Toronto, Canada
    This info is good and what I've been looking for. So given the consensus is anywhere from 320-500ISO for a clean image, and 800ISO ok too and even as high up as 1600... how would one go about shooting with streetlight lamp lighting in the neighbourhood of 6400ISO @ f2.8?
